[mapserver-users] Re: Dashed outline for polygon (migration to 6.0)
Mark Deneen mdeneen at gmail.com
Mon Aug 29 11:03:43 EDT 2011
We had an issue where, depending on your projection, the dashed lines
would only show up further north.  As they got closer to the equator,
they looked more solid.
-M
On Mon, Aug 29, 2011 at 10:22 AM, Havard Tveite <havard.tveite at umb.no> wrote:
> It works for me for 6.0.0, 6.0.1 and SVN trunk with AGG.
> I have also tried to include you OUTPUTFORMAT specification,
> and that works.  It also works with GD.
> I have been testing with shp2img.
> Håvard
> Here is a complete layer with an inline feature.
>  LAYER
>    STATUS DEFAULT
>    TYPE POLYGON
>    FEATURE
>      POINTS
>        5 5
>        5 25
>        45 25
>        45 5
>        5 5
>      END # Points
>    END # Feature
>    CLASS
>      STYLE
>        OUTLINECOLOR 0 0 0
>        WIDTH 6
>        PATTERN 20 20 END
>        LINECAP BUTT
>      END # STYLE
>    END # CLASS
>  END # LAYER
> On 8/29/2011 2:59 PM, Petra Pietrasová wrote:
>> Thank you ,
>> but even your example doesn´t work.
>> Are you using the version of mapserver 6.0.1 and does dashed line work in
>> it? if it works to you than the problem is not in the layer in the style
>> of
>> layer.
>> Do you have any idea what we do wrong? Some setup of mapserver or output?
>> We are using AGG output as I wrote before...
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Dashed-outline-for-polygon-migration-to-6-0-tp6728657p6737544.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
