[mapserver-users] Problem GetFeature with geom filter on WFS
Stéphane Brunner stephane.brunner at camptocamp.com
Mon Aug 29 11:23:23 EDT 2011
Hello,
2011/8/29 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> Hi,
> Ok, understood. Do you have enough material now for filing a bug report?
I just done it:
http://trac.osgeo.org/mapserver/ticket/4005
> The desired behaviour would be to apply && filter for the first PostGIS query with the maximun extents of the geometry included in the filter of the WFS request, but without limit [maxFeatures]?
Effectively it's not the best but it's good enough, the best is to
done the geometry filtering in postgis ;-).
Sincerely
Stéphane
> -Jukka Rahkonen-
> Stéphane Brunner wrote:
>> Hello,
>> 2011/8/24 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>> > Hi,
>> > I am not too familiar with PostGIS, but isn't this &&
>> exactly an index based
>> > BBOX query which is checking if the BBOX of the feature is
>> intersecting with
>> > the BBOX of the reference geometry?
>> > where geom &&
>> >> >> GeomFromText('POLYGON((620000 218000,620000 278000,690000
>> >> >> 278000,690000 218000,620000 218000))',-1)
>> This BBox is the Extents of the mapfile than in our case it
>> always return true.
>> >  Then perhaps what you wrote
>> > "MapServer filters them correctly but as we get
>> >> only the 100 first results from the DB, we miss many objects and/or
>> >> they are not related to the area where we want to apply a
>> geographical
>> >> filter. "
>> > could better be written "as we get only the 100 first
>> results within the
>> > BBOX filtered with fast but inaccurate index search, the
>> result set after
>> > Mapserver applying a geographical filter may have less that
>> 100 features".
>> Yes, but with a so large BBOX (extent from the mapfile, not geometry
>> extent) in most cases it returns 0 results.
>> Sincerely
>> Stéphane Brunner
>> > -Jukka Rahkonen-
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> camptocamp.com
>> mapfish.org
camptocamp.com
mapfish.org
