[mapserver-users] Re: Dashed outline for polygon (migration to 6.0)
Havard Tveite havard.tveite at umb.no
Tue Aug 30 03:44:36 EDT 2011
Interesting.  I am sure that a bug report would be appreciated.
Do you think you could create an example that demonstrates the
problem?
Håvard
On 8/29/2011 5:03 PM, Mark Deneen wrote:
> We had an issue where, depending on your projection, the dashed lines
> would only show up further north.  As they got closer to the equator,
> they looked more solid.
> -M
> On Mon, Aug 29, 2011 at 10:22 AM, Havard Tveite<havard.tveite at umb.no>  wrote:
>> It works for me for 6.0.0, 6.0.1 and SVN trunk with AGG.
>> I have also tried to include you OUTPUTFORMAT specification,
>> and that works.  It also works with GD.
>> I have been testing with shp2img.
>> Håvard
>> Here is a complete layer with an inline feature.
>>   LAYER
>>     STATUS DEFAULT
>>     TYPE POLYGON
>>     FEATURE
>>       POINTS
>>         5 5
>>         5 25
>>         45 25
>>         45 5
>>         5 5
>>       END # Points
>>     END # Feature
>>     CLASS
>>       STYLE
>>         OUTLINECOLOR 0 0 0
>>         WIDTH 6
>>         PATTERN 20 20 END
>>         LINECAP BUTT
>>       END # STYLE
>>     END # CLASS
>>   END # LAYER
>> On 8/29/2011 2:59 PM, Petra Pietrasová wrote:
>>> Thank you ,
>>> but even your example doesn´t work.
>>> Are you using the version of mapserver 6.0.1 and does dashed line work in
>>> it? if it works to you than the problem is not in the layer in the style
>>> of
>>> layer.
>>> Do you have any idea what we do wrong? Some setup of mapserver or output?
>>> We are using AGG output as I wrote before...
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/Dashed-outline-for-polygon-migration-to-6-0-tp6728657p6737544.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Håvard Tveite
>> Department of Mathematical Sciences and Technology, UMB
>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
Håvard Tveite
