RE [Polluriel potentiel] Re: [mapserver-users] Issue with run-time
substitution?
Steve.Toutant at inspq.qc.ca
Wed Aug 31 08:34:08 EDT 2011
Since you don't have a FILTERITEM I don't I don't understand why this is
working FILTER (%wfilter%)
Perhaps you should use the brackets and "" if the data type is a string
Per example, if uc is char I would write this
FILTER ("[uc]" = "%vucv%")
If it is a number
FILTER ([uc] = "%vucv%")
Stephen Davies <sdavies at sdc.com.au>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2011-08-30 21:33
Veuillez répondre à
A
mapserver-users at lists.osgeo.org
cc
Objet
substitution?
I have further reduced a test map file and changed the sequence of
statements
but one substitution still fails.
I have a number of other map files where substitution works as expected
and the
wfilter substitution in this example also works as expected but I cannot
see
what is different about the vucv case.
The URL looks like this:
http://www.agua.com.au/cgi-bin/mapserv?map=/tmp/q.map
&mapext=138.4324071+-35.2807010+138.5729945+-35.1222989
&mre=-1070114.26+-4230140.65+289096.72+-2872042.86
&wfilter=id+in+%2847%29&vucv=137_11
The minimal map file is:
# template map file for Agua Soil Database Water Mgt
MAP
NAME watermgt
PROJECTION
"proj=eqc"
"ellps=GRS80"
"towgs84=0,0,0"
"no_defs"
"lon_0=138.503e"
END
SIZE 600 600
FONTSET "/var/www/html2/benparts/fonts.list"
SYMBOLSET "/var/www/html2/benparts/symbols"
UNITS METERS
IMAGETYPE jpeg
OUTPUTFORMAT
NAME 'AGG_JPEG'
DRIVER AGG/JPEG
IMAGEMODE RGB
FORMATOPTION "QUALITY=100"
END
IMAGECOLOR 255 255 255
WEB
template /var/www/html2/benparts/templates/test1.html
imagepath "/var/www/html2/tmp/"
imageurl "/tmp/"
LOG "/tmp/mapserv.log"
END
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 94
END
STATUS ON
END
LAYER
TYPE RASTER
NAME "bkgrnd"
STATUS ON
PROJECTION
"init=epsg:4283"
END
DATA "/var/www/html2/benparts/rasters/JB_Onka_IPOS_Ver2.jpg"
PROCESSING "DITHER=YES"
END
LAYER
CONNECTIONTYPE postgis
NAME "weather"
DATA "geom from weather_station"
CONNECTION "user=scldad dbname=benparts"
PROCESSING "CLOSE_CONNECTION=DEFER"
STATUS ON
TYPE POINT
VALIDATION
wfilter 'id in.*'
END
FILTER (%wfilter%)
PROJECTION
"init=epsg:4283"
END
LABELITEM "name"
CLASS
NAME "Weather Station"
STYLE
COLOR 214 0 0
SYMBOL 'circle'
SIZE 7
END
LABEL
MINDISTANCE 150
POSITION CR
SIZE TINY
COLOR 9 9 9
STYLE
GEOMTRANSFORM 'labelpoly'
COLOR 255 255 255
END
END
END
END
LAYER
NAME "battery"
VALIDATION
vucv '.*'
END
DATA "geom from wmd using unique id using SRID=4283"
STATUS ON
TYPE POINT
FILTER (uc='%vucv%' and stype='B')
PROJECTION
"init=epsg:4283"
END
MAXSCALE 5000000
LABELITEM "label"
CLASSITEM "state"
CLASS
EXPRESSION "G"
STYLE
COLOR 0 255 0
SYMBOL 'dot'
SIZE 7
OFFSET 17 0
END
LABEL
POSITION CR
TYPE TRUETYPE
FONT arial
SIZE 8
COLOR 0 255 0
OFFSET 20 0
FORCE TRUE
STYLE
COLOR 255 255 255
END
END
END
CLASS
EXPRESSION "A"
STYLE
COLOR 255 215 0
SYMBOL 'dot'
SIZE 7
OFFSET 17 0
END
LABEL
POSITION CR
TYPE TRUETYPE
FONT arial
SIZE 8
COLOR 255 215 0
OFFSET 20 0
FORCE TRUE
STYLE
COLOR 255 255 255
END
END
END
CLASS
EXPRESSION "R"
STYLE
COLOR 255 0 0
SYMBOL 'dot'
SIZE 7
OFFSET 17 0
END
LABEL
POSITION CR
TYPE TRUETYPE
FONT arial
SIZE 12
COLOR 255 0 0
OFFSET 20 0
FORCE TRUE
STYLE
COLOR 255 255 255
END
END
END
END
# Start of reference map
REFERENCE
IMAGE /var/www/html2/benparts/refmaps/sa.png
EXTENT -1070114.26 -4230140.65 289096.72 -2872042.86
SIZE 120 120
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR 0 255 0
OUTLINECOLOR 0 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS ON
END
END
When I run this, the Postgresql log shows:
LOG: duration: 0.127 ms execute <unnamed>: select
"name",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex') as geom,"id"
from
weather_station where geom && GeomFromText('POLYGON((138.42349975
-35.280701,138.42349975 -35.1222989,138.58190185 -35.1222989,138.58190185
-35.280701))',find_srid('','weather_station','geom'))
and (id in (47))
LOG: duration: 0.060 ms execute <unnamed>: select
"state","label",encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex') as
geom,"id" from wmd where geom && GeomFromText('POLYGON((138.42349975
-35.280701,138.42349975 -35.280701))',4283) and (uc='%vucv%' and
stype='B')
This illustrates that the wfilter substitution worked but the vucv
substitution
did not.
Cheers,
Stephen
Stephen Davies Consulting P/L Voice: 08-8177
1595
Adelaide, South Australia. Fax : 08-8177
0133
Records & Collections Management. Mobile:040 304
0583
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110831/70281f02/attachment.html
