[mapserver-users] Issue with run-time substitution?
Steve Lime
sdlime at gmail.com
Wed Aug 31 09:47:28 EDT 2011
Hmm... Looks like it's setup correctly although you validation pattern isn't strong enough. As a test what happens if you try a pattern like '.'? If that works then it's a regex error. One thing that comes to mind is that maybe there's query string parsing issue and the var to substitute isn't being recognized. Spaces or other chars ahead of &var could mess things up. Something to check.
Steve
Sent from my iPad
On Aug 30, 2011, at 6:43 AM, Stephen Davies <sdavies at sdc.com.au> wrote:
> I am running mapserver 6.0.1 with map files migrated from 5.6.3.
> One of my map files has stopped working properly and I suspect that it may be a
> bug in the 6.0.1 run-time substitution code.
> The relevant map file layer sections look like this:
> LAYER
> CONNECTIONTYPE postgis
> NAME "battery"
> DATA "geom from wmd using unique id using SRID=4283"
> CONNECTION "user=scldad dbname=benparts"
> STATUS ON
> TYPE POINT
> VALIDATION
> vucv '[0-9]*_[0-9]*'
> END
> FILTER (stype='B' and uc='%vucv%')
> PROJECTION
> "init=epsg:4283"
> END
> MAXSCALE 5000000
> LABELITEM "label"
> CLASSITEM "state"
> CLASS
> EXPRESSION "G"
> STYLE
> COLOR 0 255 0
> SYMBOL 'dot'
> SIZE 7
> OFFSET 17 0
> END
> LABEL
> POSITION CR
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> COLOR 0 255 0
> OFFSET 20 0
> FORCE TRUE
> STYLE
> GEOMTRANSFORM 'labelpoly'
> COLOR 255 255 255
> END
> END
> END
> END
> There are twelve layers with essentially the same definition apart from the
> STYPE values.
> The invoking URL has &vucv=137_11 but the postgresql log reveals that no
> substitution has occurred. The final pgsql command still has '%vucv%'.
> I suspect that having more than one FILTER with the same substitution breaks
> things as all other substitutions work fine.
> (I also tried putting the substitution in the DATA entry but with no better
> result.)
> Cheers,
> Stephen
> Stephen Davies Consulting P/L Voice: 08-8177 1595
> Adelaide, South Australia. Fax : 08-8177 0133
> Records & Collections Management. Mobile:040 304 0583
> mapserver-users at lists.osgeo.org
