[mapserver-users] Re: Mapserver 6.0.1 -- Label Class not recognizing token BACKGROUNDCOLOR
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Dec 1 10:09:34 EST 2011
That's correct. The labelpnt is really the computed point based on the type of a geometry we're processing. For a point it's, well, just the point. For a polygon it's based on a number of successively complex computations to make sure the point is in the polygon- starting with the center of the features bbox and ending with a center of gravity computation. Lines use the middle of the longest segment.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Havard Tveite
Sent: Thursday, December 01, 2011 8:24 AM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Re: Mapserver 6.0.1 -- Label Class not recognizing token BACKGROUNDCOLOR
Thanks, Thomas.
I changed it to:
"labelpnt generates the point relative to which the label
will be placed."
Better?
Håvard
On 12/1/2011 8:58 AM, thomas bonfort wrote:
> Havard,
> "labelpnt generates a point with its center at the middle of the
> bounding rectangle of the text."
> Unless there's a problem with the code, this is not the behavior of
> the labelpnt geomtransform. The point created by labelpnt is dependant
> on the label's POSITION, i.e. it is the center of the text's bounding
> rectangle only if the label is in position CC.
> regards,
> thomas
> On Thu, Dec 1, 2011 at 08:47, Havard Tveite<havard.tveite at umb.no>  wrote:
>> The documentation has been updated.   An example of GEOMTRANSFORM
>> usage has been added in the label document under STYLE.
>> http://gis.umb.no/~havatv/mapserver/docs/mapfile/label.html#label-style
>> Håvard
>> On 11/30/2011 5:09 AM, Stephen Woodbridge wrote:
>>> On 11/29/2011 10:19 PM, Matt Pettis wrote:
>>>> I see upon reading closer that it is deprecated... but I thought that
>>>> meant
>>>> it was discouraged, but not yet removed.  That must not be true... I am
>>>> now
>>>> working to find a GEOMTRANSFORM example to help me do the equivalent.
>>> Hi Matt,
>>> These should help you:
>>> http://mapserver.org/mapfile/style.html
>>> http://mapserver.org/development/rfc/ms-rfc-72.html
>>> http://mapserver.org/trunk/MIGRATION_GUIDE.html
>>> Also please write a Bug and assign it to the Documentation and the fact
>>> that it has been removed. It might be nice to add a comment in the docs
>>> that points to the MIGRATION_GUIDE.
>>> Thanks,
>>>     -Steve W
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Håvard Tveite
>> Department of Mathematical Sciences and Technology, UMB
>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
Håvard Tveite
