[mapserver-users] Prnting WMS layers
Bistrais, Bob Bob.Bistrais at maine.gov
Thu Dec 1 10:25:56 EST 2011
Hi Brent,
I'll admit to some ignorance here, not sure how to use the curl command
in that capacity- do you have an example?
Regarding the output format, here is what I have on the WMS server side:
OUTPUTFORMAT
  NAME "agg"
  DRIVER "AGG/PNG"
  MIMETYPE "image/png"
  EXTENSION PNG
  IMAGEMODE RGBA
  TRANSPARENT ON
  FORMATOPTION "INTERLACE=OFF"
END
-But I'm still looking for something on the client side (GeoMoose side)
which might be manipulating that image, since this problem is only
happening with the printed map images.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, December 01, 2011 10:14 AM
To: Bistrais, Bob
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Prnting WMS layers
Bob,
  Sounds like the "type" of PNG is causing the problem.  Have a look at
the properties (using gdalinfo) of the PNG image the wms produces (use
"curl" to get and save the image.  Is it RGB? RGBA?
Best Regards,
Brent Fraser
On 12/1/2011 7:31 AM, Bistrais, Bob wrote:
Hi Adam,
I doubt it, but I won't rule out anything.  But the MapServer (non-WMS)
layers display fine, so that's one thing that doesn't make sense.
Sent: Wednesday, November 30, 2011 5:23 PM
To: Bistrais, Bob
Is it possible the issue is with the CSS of your print stylesheet?
On Wed, Nov 30, 2011 at 3:30 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
wrote:
Hi all,
I've posted this to the GeoMoose list since the problem was occurring in
a GeoMoose application, but also would like to see what insights there
may be here on the MapServer list.  Sorry for any duplication.
I have a few WMS layers that I consume in GeoMoose. Some of these are
vector line layers such as roads. They look correct in the application's
map view. But when I compose a printable map, these layers have a black
background which obscures other layers. If I set the "transparent"
property to false, the black background goes away, but then I can't see
any underlying data.
By the way, I do have control over the WMS services in this case. I
tried to set Offsite to 0 0 0, but that didn't seem to help either. The
image format should be png, and as best as I can tell, this is what it's
producing.  The WMS is at MapServer 6.0.1, while the application is at
MS 5.6.  It appears to be some problem with the alpha channels. Any
suggestions?
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111201/ae667149/attachment.html
