[mapserver-users] Using OSM with our own data
Matt McClelland matt at wildwalks.com
Sat Dec 3 03:30:59 EST 2011
Hi Nico
I have done the same thing.  Using OSM data as a base layer (in a DB) and
then have added extra layers to the mapserver-utils mapfile.  It worked
fine for me.
I got had trouble at one point as I was not using the PROJECTION tag in the
layer.  This fixed the issue for me.
Can I suggest you start with a very simple layer to just get it started,
then build it up from there.  If you copy and paste a large lot in I have
found it easy to get lost and hard to find/fix any issues.
You can refer to many different map data sources as you need.
Matt  :)
On Fri, Dec 2, 2011 at 3:36 AM, Nico Alberti <n8 at langhirano.it> wrote:
> Hi everybody.
> After quite a long time I am back using mapserver. Seeing how well it is
> cabable of rendering OSM data I would like to use it as a background for
> the geographical information I would like to display. I followed the nice
> howto and now my new Mapserver setup is ready to display a local stored
> portion of Openstreetmap OR my own data, not both :-)
> The problem, as far as I know,  is that I cannot successfully merge the
> mapfile I created for my data and the one automatically generated by the
> mapserver-utils mapfile generator; if I try to paste the LAYER part
> containing my data, it is apparently ignored (and not even wrongly
> projected, as far as I can see). Is there any caveat I can be aware of or,
> better, is there some other doc explaining the use of OSM data with other
> layers?
> Thank you in advance and sorry for my poor English
> Ciao
> Nico
> ______________________________**_________________
> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111203/2b5c5b6e/attachment.html
