[mapserver-users] Trouble with OGR output and writing to temppath
Matt McClelland
matt at wildwalks.com
Sun Dec 4 06:02:01 EST 2011
Check if you have enough disk space left
df -alh
Matt :)
Sent from my iPhone
On 04/12/2011, at 9:29 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> I have troubles with getting the ORG output to work.
> I have configured CVS ouput like this
> OUTPUTFORMAT
> NAME "CSV"
> DRIVER "OGR/CSV"
> MIMETYPE "text/csv"
> FORMATOPTION "LCO:GEOMETRY=AS_WKT"
> FORMATOPTION "STORAGE=filesystem"
> FORMATOPTION "FORM=simple"
> FORMATOPTION "FILENAME=result.csv"
> END
> I have set TEMPPATH in the MAP/WEB
> WEB
> TEMPPATH "/usr/temp/"
> /usr/temp directory has 0777 permissions. Mapserver can write error.log file into that directory without troubles.
> WFS works normally with outputformats GML2 and GML3. However, WFS requests with CSV outputformat fails and I am getting error messages like this:
> msOGRWriteFromQuery(): General error message. Failed to open result file '/usr/temp/4edb45fd_707c_0/result.csv'.
> Error.log file is also listing all the features and all the attributes so the query itself is successful.
> I am trying this with Ubuntu server and Mapserver version is 6.0.1. It is also odd that I am sure that I did manage to get valid zipped shapefiles out from this same server a couple of days ago but now all that I am getting back is empty zipfile. Error.log does not report about any error in this case.
> Any suggestions what to try next or what to do for finding the ultimate reason for the error?
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
