[mapserver-users] Trouble with OGR output and writing to temppath
Smith, Michael ERDC-CRREL-NH
Michael.Smith at usace.army.mil
Sun Dec 4 09:32:25 EST 2011
Jukka,
I've started having this issue on Windows mapserver just recently. I have
not had this problem on unix. Not sure if this is a mapserver issue or a
gdal one.
I get similar errors to yours:
msOGRWriteFromQuery(): General error message. OGR CreateDataSource failed
for 'C:/cm2_files/tmp/4edb808b_178_0/ship_locations.gdb.zip' with driver
'FileGDB'.
It appears to only happen with FORMATOPTION "STORAGE=filesystem".
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 12/4/11 6:22 AM, "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi> wrote:
>Hi,
>Thanks, natural thing that I had not checked. Fortunately or
>unfortunately, none of the mounts seem to have more than 2% used. I
>guess that writing the request output to error.log located in the same
>mount would also fail in that case.
>-Jukka-
> Matt McClelland wrote:
>> Check if you have enough disk space left
>> df -alh
>> Matt :)
>> Sent from my iPhone
>On 04/12/2011, at 9:29 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>wrote:
>> Hi,
>> I have troubles with getting the ORG output to work.
>> I have configured CVS ouput like this
>> OUTPUTFORMAT
>> NAME "CSV"
>> DRIVER "OGR/CSV"
>> MIMETYPE "text/csv"
>> FORMATOPTION "LCO:GEOMETRY=AS_WKT"
>> FORMATOPTION "FORM=simple"
>> FORMATOPTION "FILENAME=result.csv"
>> END
>> I have set TEMPPATH in the MAP/WEB
>> WEB
>> TEMPPATH "/usr/temp/"
>> /usr/temp directory has 0777 permissions. Mapserver can write
>>error.log file into that directory without troubles.
>> WFS works normally with outputformats GML2 and GML3. However, WFS
>>requests with CSV outputformat fails and I am getting error messages
>>like this:
>> msOGRWriteFromQuery(): General error message. Failed to open result
>>file '/usr/temp/4edb45fd_707c_0/result.csv'.
>> Error.log file is also listing all the features and all the attributes
>>so the query itself is successful.
>> I am trying this with Ubuntu server and Mapserver version is 6.0.1. It
>>is also odd that I am sure that I did manage to get valid zipped
>>shapefiles out from this same server a couple of days ago but now all
>>that I am getting back is empty zipfile. Error.log does not report about
>>any error in this case.
>> Any suggestions what to try next or what to do for finding the ultimate
>>reason for the error?
>> -Jukka Rahkonen-
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
