[mapserver-users] Maperver upgrade 5.6 - 6.0 - OUTPUTFORMAT ?
thomas bonfort thomas.bonfort at gmail.com
Thu Dec 8 09:13:00 EST 2011
antialiasing causes vertical and horizontal lines to appear blurred.
switch to gif if you need aliased results.
thomas
On Thu, Dec 8, 2011 at 14:58, tommaso <tommasodb at googlemail.com> wrote:
> Hallo List,
> I'm trying to upgrade my app from Mapserver 5.6 to Mapserver 6.0.
> The Problem is, that the same Mapfile produces two different maps with the
> to Mapserver version. The map by mapserver 6.0 appears like "out of focus".
> See the attachments for a example. I'm missing something regarding
> OUTPUTFORMAT?
> In the WMS Request I'm using  " format=png " or  " format=png24 ", with the
> same result.
> The mapfile is below.
> Greetings Tommaso
> MAP
>     NAME test-map
>     STATUS ON
>     UNITS meters
>     IMAGETYPE AGG
>     OUTPUTFORMAT
>        NAME 'AGG'
>        DRIVER AGG/PNG
>        IMAGEMODE RGB
>     END
>     PROJECTION
>         "proj=utm"
>         "zone=32"
>         "ellps=WGS84"
>         "datum=WGS84"
>         "units=m"
>         "no_defs"
>         "towgs84=0,0,0"
>     END
>     WEB
>         IMAGEPATH "/tmp/mapserver"
>         IMAGEURL "/tmp/mapserver"
>         METADATA
>             WMS_SRS "epgs:32632"
>             ows_enable_request   "*"
>         END
>     END
>     LAYER
>         NAME "stand_test"
>         STATUS ON
>         TYPE POLYGON
>         INCLUDE "connection"
>         DATA "geom from geo.stand_test  using UNIQUE id USING srid=32632"
>         LABELITEM  "name"
>         CLASS
>             STYLE
>                 #COLOR '#ffffff'
>                 OUTLINECOLOR  '#000000'
>             END
>         END
>     END
> END       ### END MAP #####
> mapserver-users at lists.osgeo.org
