[mapserver-users] Re: Georeferenced PDF output
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Fri Dec 9 08:22:31 EST 2011
If it needs coding then it is not for me but I do not have any immediate need either. I was just thinking that if the georeferencing method is published and open and if it mainly means, as I suppose, embedding some code box in the pdf file then perhaps Mapserver could be made to do it while generating the pdf output. But maybe it is not so easy. Wikipedia does not know any open source software writing out geospatial PDF http://en.wikipedia.org/wiki/Geospatial_PDF
-Jukka Rahkonen-
Sumit Sharma wrote:
> Hi Jukka,
> though there is no direct way of producing GeoPDF in
> MapServer, however you
> can write small code using iText and mapscript that can
> consume output of
> Mapserver and convert it into GeoPDF. I have done same thing using 5.2
> version of mapserver to create layered GeoPDF.
> Thanks,
> Sumit.
> Hi,
> Mapserver can output PDF but can it produce also
> georeferenced PDF files?
> -Jukka Rahkonen-_______________________________________________
> [hidden email]
> http://osgeo-org.1803224.n2.nabble.com/Georeferenced-PDF-outpu
> t-tp7053683p7078019.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
