[mapserver-users] GEOMTRANSFORM LABELPNT example
Ian Walberg ian.walberg at airborne.aero
Sun Dec 11 16:18:24 EST 2011
So is it expected that labelpnt generates a point with its center at the middle of the bounding rectangle of the text?
Thanks
Ian
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Sunday, December 11, 2011 1:02 PM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] GEOMTRANSFORM LABELPNT example
Thomas,
  I tracked it down to the LABELCACHE setting.
LABELCACHE ON  gives the expected results LABELCACHE OFF  gives my old blue-dot-on-the-left results.
See attached PDFs.
Best Regards,
Brent Fraser
On 12/11/2011 1:05 PM, thomas bonfort wrote:
> There might have been a bug in the initial implementation. trying it
> out with current trunk gives me the expected result, unless I'm
> missing something.
> On Sun, Dec 11, 2011 at 20:44, Brent Fraser<bfraser at geoanalytic.com>  wrote:
>> Thomas,
>>   See comments below.
>> Best Regards,
>> Brent Fraser
>> On 12/11/2011 12:26 PM, thomas bonfort wrote:
>>> I think this is all expected behavior, although the documentation
>>> may be incorrect.
>>> LABELPNT draws a marker on the geographic position the label is
>>> attached to. This corresponds to the center of the label text only
>>> if the label is in position CC.
>> I think that is what is intended but my original test case (using CC
>> ) resulted in the LABELPNT rendered on the left side of the
>> labelpoly, see http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110526/47c9bc8c/labelpnt-0001.png.
>>    I had expected it to be coincident with the yellow circle and green cross.
>>> To draw a label at the center of the label text, another
>>> geomtransform would have to be implemented, named e.g. LABELBBOXCENTROID.
>> or maybe
>> GEOMTRANSFORM (centroid([LABELPOLY]))
>>> regards,
>>> thomas
>>> On Sun, Dec 11, 2011 at 19:34, Brent Fraser<bfraser at geoanalytic.com>
>>>   wrote:
>>>> Hey Jeff,
>>>>   I've been looking into this too (not finished yet).  I'm using
>>>> v6.0.1 and can reproduce my original results (blue dot to the left)
>>>> AND Ian's (grey dot coincident with white dot).  Very strange.  My
>>>> shapefile dataset gets reprojected from geographic to UTM, so that
>>>> may be causing the difference.
>>>>   I need to look into that...
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 12/11/2011 10:57 AM, Jeff McKenna wrote:
>>>>> On 11-12-11 11:20 AM, Ian Walberg wrote:
>>>>>> Here is the map file we are using ms4w 3.0.3.
>>>>>> We thought the larger grey circle should be drawn in the center
>>>>>> of the label text.
>>>>>> What have we done wrong?
>>>>> I have done some testing on this on Windows, with MapServer trunk
>>>>> (6.1-dev), here are my findings:
>>>>> - I used Brent's original example styles (from
>>>>> http://osgeo-org.1803224.n2.nabble.com/GEOMTRANSFORM-labelpnt-location-td6408065.html)
>>>>> with Ian's FEATURE layer -->    Brent's "Blue Dot" LABELPNT with POSITION
>>>>> CC is
>>>>> now correctly placed in the center of the label text (so it seems
>>>>> this has been fixed in the code, but I can't find the ticket that
>>>>> says that)
>>>>> - If I change to POSITION LR (as in Ian's example layer) then I
>>>>> get Ian's issue (LABELPNT is placed at the geometry location, not
>>>>> - but this is now an issue of understanding the developer's logic
>>>>> (from that thread SteveL says "Let me ponder this and get back to
>>>>> you. I think it makes sense to use the label point geotransform
>>>>> only with position CC so that it matches actual shape location.")
>>>>> That's all I know at this point (ha pun).
>>>>> -jeff
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
