[mapserver-users] small mapserver admin tool errors
kaaos moizkfov at gmail.com
Mon Dec 12 16:30:27 EST 2011
Hi.
Im writing a small admin tool for MapServer for own use in PHP with
MapScript.
I'm building a mapfile object with ms_newMapObj() and then throwing elements
into database, forms, etc.
I've got this problem that when a mapfile has errors (pure simple like
'IMAGETYPE "pnhgg"' instead 'IMAGETYPE "png"') the mapscript parser throws
an
error and the whole application stops.
The thing is that I want the application on to at least tell the user, that
his
mapfile has errors and for example open a textarea where the user could edit
his
whole mapfile without throwing it to ms_newMapObj().
I tried many things but nothing seems to work. The thing is, it's
msPostMapParseOutputFormatSetup() which actually crashes and which is used
by
ms_newMapObj(). I dont have access to msPostMapParseOutputFormatSetup().
Sample:
A PHP Error was encountered
Severity: Warning
Message: ms_newMapObj(): [MapServer Error]:
msPostMapParseOutputFormatSetup():
Unable to select IMAGETYPE `pnfg'.
Filename: controllers/program.php
Line Number: 35
Fatal error: Uncaught exception 'MapScriptException' with message 'Failed to
open map file "D:\ms4w\Apache\htdocs\p3\p3.map"' in
D:\ms4w\Apache\htdocs\ci_doctrine\system\application\controllers\program.php:35
Stack trace: #0
D:\ms4w\Apache\htdocs\ci_doctrine\system\application\controllers\program.php(35)
: ms_newMapObj('D:\ms4w\Apache\...') #1
D:\ms4w\Apache\htdocs\ci_doctrine\system\application\controllers\program.php(10)
: Program->index() #2 [internal function]: Program->save_f_tmp() #3
D:\ms4w\Apache\htdocs\ci_doctrine\system\codeigniter\CodeIgniter.php(236):
call_user_func_array(Array, Array) #4
D:\ms4w\Apache\htdocs\ci_doctrine\index.php(115):
require_once('D:\ms4w\Apache\...') #5 {main} thrown in
on
line 35
open map file "D:\ms4w\Apache\htdocs\map_file\map_file.map"' in
D:\ms4w\Apache\htdocs\ci_doctrine\system\application\controllers\load_controler.
php:35 Stack trace: #0
php(35): ms_newMapObj('D:\ms4w\Apache\...') #1
php(10): Program->index() #2 [internal function]: Program->svft() #3
php on line 35
Thanks for any help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/small-mapserver-admin-tool-errors-tp7087821p7087821.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
