[mapserver-users] [WMS] Styles not working with mode=tile
Guillaume Loiselle loiselle.guillaume at gmail.com
Fri Dec 16 08:18:59 EST 2011
I can't help you but I'll add that specifying an output format is useless,
at least with GMAP tile-mode. Whatever you ask for, you'll receive png. I
assumed it was an intended behaviour and supposed googleMap could only use
png as an input. Be it the case or not, it would be nice if we could
specify the format...
Guillaume Loiselle
P.S. : message to developers :
I think that the tile-mode should only be used as an alternative way to
determine the bbox. Other options should not be limited when tile-mode is
used. More importantly, we should not be obliged to use a tile-mode way of
requesting to use tile_map_edge_buffer.
You may disagree and have good programming design reasons to do so. I just
wanted to give a user's point of view.
2011/12/16 Clément MONIER <Clement.MONIER at v-trafic.com>
> Hi,****
> I’m applying styles to my list of layers inside a WMS request, using the
> classgroup/class/group system in the mapfile.****
> It works fine when no “tile mode” is used (bbox instead) :****
> If I launch this request ****
> http://mapserver/cgi-bin/mapserv.exe?map=mymapfile.map&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=layer1&STYLES=style2&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&CRS=EPSG:4326&bbox=-35,10,52,15&WIDTH=600&HEIGHT=600
> style2 is applied to layer1****
> But it doesn’t work if the request uses tile mode :****
> http://mapserver/cgi-bin/mapserv.exe?map=mymapfile.map&SERVICE=WMS&REQUEST=GetMap&VERSION=1.3.0&LAYERS=layer1&STYLES=style2&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&CRS=EPSG:4326&tile=0+0+0&tilemode=gmap&mode=tile&WIDTH=600&HEIGHT=600
> style2 is not applied (default style is applied)****
> Is there a way to apply styles in tile mode ?****
> Thanks & Regards****
> *Clément *****
> ps : config ****
> MS4W****
> MapServer v5.6****
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111216/b7124fd1/attachment.html
