[mapserver-users] wfs problem <gml:null>missing</gml:null>
Smith, Michael ERDC-CRREL-NH Michael.Smith at usace.army.mil
Sat Dec 17 10:32:49 EST 2011
Your data is not in projection epsg:4326 as indicated by
<gml:boundedBy><gml:Box
srsName="EPSG:4326"><gml:coordinates>3449790.000000,5891640.000000
3470274.000000,5940811.000000</gml:coordinates></gml:Box></gml:boundedBy><g
ml:featureMember><ms:Testdatenlayer
fid="Testdatenlayer.1"><gml:boundedBy><gml:Box
srsName="EPSG:4326"><gml:coordinates>3463543.000000,5900876.000000
You need to find out what projection your data is in and then set that
projection in the mapfile layer
LAYER
        PROJECTION
          'init=epsg:4326'   <-------  change this value to the epsg code
of your data
        END
        SYMBOLSCALE 50000
        NAME         'Testdatenlayer'
MapServer will then be able to reproject your data on the fly to
epsg:4326, which is the output projection of your mapfile.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 12/17/11 9:33 AM, "dstroeer at uni-osnabrueck.de"
<dstroeer at uni-osnabrueck.de> wrote:
>Hello,
>I'm testing a WFS-Layer in OpenLayers.  So first of all I set up a WFS in
>epsg:4326. You can see the mapfile below...
>Now I want to put his WFS into a OpenLayers project. Here we've got a
>simple OpenStreetMap WMS, also in epsg:4326. But when I'm testing my
>OpenLayers application (code below), I don't see my WFS layer.
>So I'm using firebug and I can see that OpenLayers tries the following
>request:
>http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/mapserverII
>/wms_wfs/wfs_ogc/wfs_server_4326.map&TYPENAME=Testdatenlayer&SERVICE=WFS&V
>ERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=3.60546875,50.8027343
>75,12.39453125,55.197265625
>When I try this request in Firefox, I'm getting the following result:
><wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
>http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
>http://mapserver.gis.umn.edu/mapserver
>/wms_wfs/wfs_ogc/wfs_server_4326.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=Des
>cribeFeatureType&TYPENAME=Testdatenlayer&OUTPUTFORMAT=XMLSCHEMA"><gml:boun
>dedBy><gml:null>missing</gml:null></gml:boundedBy></wfs:FeatureCollection>
>When I'm cutting the BBOX parameter like this
>I can see a list of my features:
>gml:featureMember><ms:Testdatenlayer
>It seems to be a projection problem, but I don't know where...
>So now I want to ask if there are any problems with my mapfile or if I
>made another mistake?
>Thanking you in anticipation,
>D. Stroeer
>##########################    mapfile   ###########################
>MAP
>  NAME                 'Testkarte WFS'
>  STATUS               ON
>  IMAGETYPE            PNG
>  #EXTENT              3430018 5876533 3491970 5948485
>  EXTENT               7.855 53.034 8.866 53.646
>  UNITS                meters
>  SIZE                 500 500
>  IMAGECOLOR           220 220 220
>  SHAPEPATH
>'C:/ms4w/Apache/htdocs/mapserverII/wms_wfs/wfs_ogc/data/'
>  SYMBOLSET
>'C:/ms4w/Apache/htdocs/mapserverII/wms_wfs/wfs_ogc/symbols/symbols.sym'
>  FONTSET
>'C:/ms4w/Apache/htdocs/mapserverII/wms_wfs/wfs_ogc/fonts/fonts.list'
>WEB
>    TEMPLATE             'template.html'
>    IMAGEPATH            'C:/ms4w/Apache/htdocs/tmp/'
>    IMAGEURL             '/tmp/'
>  METADATA
>    "WFS_TITLE"        "WFS-Test"
>    "WFS_SRS"          "epsg:4326"
>    "WFS_ABSTRACT"     "Ein kleiner WFS-Test"
>    "WFS_ONLINERESOURCE"
>"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/mapserverI
>I/wms_wfs/wfs_ogc/wfs_server_4326.map"
>    "wfs_enable_request" "*"  # necessary
>  END
>END
>PROJECTION
>     "init=epsg:4326"
>END
>    LAYER
>        PROJECTION
>          'init=epsg:4326'
>        END
>        SYMBOLSCALE 50000
>        TYPE         POINT
>        TOLERANCE   5
>        STATUS    ON
>        DATA 'testdaten_4326.shp'
>        DUMP TRUE
>        METADATA
>          "WFS_TITLE" "Testdaten"
>          "gml_featureid" "id"
>          "GML_INCLUDE_ITEMS" "all"
>        END
>        CLASS
>          STYLE
>            SYMBOL    'square'
>            COLOR     200 0 0
>            SIZE 9
>            MINSIZE 9
>            MAXSIZE 15
>          END
>        END
>    END
>END
>######################   OpenLayers Application
>    <script src="../lib/OpenLayers.js"></script>
>    <script type="text/javascript">
>        var lon = 8;
>        var lat = 53;
>        var zoom = 8;
>        var map, layer;
>        function init(){
>            map = new OpenLayers.Map( 'map');
>            layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>                    "http://vmap0.tiles.osgeo.org/wms/vmap0", {layers:
>'basic'}
>              var weserwfs = new OpenLayers.Layer.WFS(
>                "WFS-Test",
>I/wms_wfs/wfs_ogc/wfs_server_4326.map",
>                {typename: 'Testdatenlayer'},
>      extractAttributes: true,
>     styleMap: new OpenLayers.StyleMap({
>        pointRadius: 8,
>        fillColor: '#ee0000',
>        fillOpacity: 0.5,
>        strokeColor: '#ee0000',
>        strokeOpacity: 1,
>        strokeWidth: 3
>            map.addLayer(layer);
>            map.addLayer(weserwfs);
>            map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>            map.addControl( new OpenLayers.Control.LayerSwitcher() );
>            map.addControl( new OpenLayers.Control.OverviewMap() );
>            map.addControl( new OpenLayers.Control.ScaleLine() );
>            map.addControl( new OpenLayers.Control.MousePosition() );
>    </script>
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
