[mapserver-users] Multi-Resolution Terrain Map File
Brent Fraser
bfraser at geoanalytic.com
Sat Dec 24 11:38:51 EST 2011
Here's a more current link:
http://www.gdal.org/gdaldem.html
And you could look into the VRT format to see if can help with the nodata
problem.
> You could use the OFFSITE value in the higher resolution layer.
> Basically in this scheme, mapserver would render each layer, and any
> place with an OFFSITE value would show the value from the layer under
> it.
> A more basic problem is how do you want the elevation value to be
> rendered to a visible image? You could use GDAL to pre-process the
> SRTM DEMs (http://www.perrygeo.net/wordpress/?p=7), or use mapserver to
> classify the DEM values to colors on the fly.
> Best Regards,
> Brent Fraser
>> How do I construct a map file that can handle different resolutions of
>> terrain, with fallback to lower resolution when a no-value is found? In
>> Google Earth Fusion, I can specify multiple terrain sources and tell it
>> which value(s) represent missing data, and it will then process the
>> terrain, checking for availability of each type of terrain, falling back
>> if there isn't any in a geographic area and falling back if there is
>> missing data.
>> For simple fallback based on area coverage, I can use a map file like
>> the
>> one below (using 30 Arcsecond SRTM and 1 Arcsecond DTED). Now, what
>> would
>> I need to do to have it use/interpolate data from the 30 Arcsecond
>> values
>> when there is a missing data/NODATA/hole in the DTED? In the file
>> below,
>> gdaltindex has been used to generate the coverage shapefiles.
>> The example below is a simple one, and it would be really helpful to be
>> able to have multiple terrain sources and a way to automatically fill
>> voids the same way that transparency works with raster image layers.
>> Specifying that terrain values are posts and not pixels would be good
>> too,
>> but lower priority.
>> Xander
>> MAP
>> NAME "srtm"
>> EXTENT -180 -90 180 90
>> SIZE 512 512
>> UNITS DD
>> IMAGETYPE bil
>> PROJECTION
>> "init=epsg:4326"
>> END
>> OUTPUTFORMAT
>> NAME "bil"
>> DRIVER "GDAL/EHdr"
>> MIMETYPE "image/bil"
>> EXTENSION "bil"
>> IMAGEMODE INT16
>> END
>> OUTPUTFORMAT
>> NAME "bil16"
>> DRIVER "GDAL/EHdr"
>> MIMETYPE "application/bil16"
>> EXTENSION "bil"
>> IMAGEMODE INT16
>> END
>> OUTPUTFORMAT
>> NAME "gtiff_16"
>> DRIVER "GDAL/GTiff"
>> MIMETYPE "image/tiff"
>> EXTENSION "tif"
>> IMAGEMODE INT16
>> END
>> WEB
>> IMAGEPATH "/tmp/"
>> IMAGEURL "/tmp/"
>> LOG "/tmp/srtm.err"
>> METADATA
>> wms_title "SRTM Terrain"
>> END
>> END
>> # Coarse (30 ArcSecond) terrain. There is worldwide coverage, so this
>> # is good for areas uncovered by SRTM data, as well as for high
>> # scale values.
>> LAYER
>> NAME "srtm"
>> TILEINDEX "SRTM30/bathmetry.shp"
>> TYPE RASTER
>> PROCESSING "RESAMPLE=BICUBIC"
>> STATUS ON
>> METADATA
>> "wms_title" "SRTM 30 ArcSecond Bathmetry"
>> "wms_group_title" "srtm30"
>> "wms_srs" "epsg:4326"
>> "wms_style" "Default"
>> "wms_extent" "-180 -90 180 90"
>> END
>> MAXSCALEDENOM 1000000000
>> MINSCALEDENOM 10
>> END
>> # Moderate resolution (1 ArcSecond) terrain. Coverage is available
>> worldwide
>> # for most land areas between latitudes -60 and +60.
>> LAYER
>> NAME "srtm"
>> TILEINDEX "srt2f_1/srt2f_1.shp"
>> TYPE RASTER
>> STATUS ON
>> METADATA
>> "wms_title" "SRTM 1 ArcSecond Bathmetry"
>> "wms_extent" "-180 -60 180 60"
>> END
>> END
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
