[mapserver-users] RE: failed to open map file - MS 6.0 to 6.0.1
Bistrais, Bob
Bob.Bistrais at maine.gov
Wed Dec 28 16:50:30 EST 2011
Thanks Mike,
Looking at that now. Does the same apply to Cartoline? I seem to be
having issues with those symbols as well.
-----Original Message-----
From: Smith, Michael ERDC-CRREL-NH [mailto:Michael.Smith at usace.army.mil]
Sent: Wednesday, December 28, 2011 4:08 PM
To: Bistrais, Bob; Stephen Woodbridge; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] RE: failed to open map file - MS 6.0 to
6.0.1
Bob,
STYLE at the SYMBOL level was renamed PATTERN in 5.0 and removed in v6.
This is a dashed line and now the PATTERN is applied at the LAYER level
rather than at the SYMBOL.
You should remove the STYLE..END block from the SYMBOL and apply it as a
PATTERN at the LAYER level (see
http://mapserver.org/mapfile/style.html#style)
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 12/28/11 3:58 PM, "Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
>Not sure if this helps, but here's the first few lines of the symbol
>file- notice that line 6 contains the Style keyword. Does anything
look
>out of place with that?
>SYMBOL
> NAME 'county-line'
> TYPE ELLIPSE
> POINTS 2 2 END
> FILLED true
> STYLE 4 2 2 4 END
>END
>From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
>Sent: Wednesday, December 28, 2011 11:31 AM
>To: mapserver-users at lists.osgeo.org
>6.0.1
>Hi Bob,
>What does the top 15+- lines of your mapfile look like?
>This error is in loadSymbol, do you have a reference to a symbol file?
>is this where the error is coming from? Are you sure you are loading
the
>correct symbol file?
>-Steve W
>On 12/28/2011 11:20 AM, Bistrais, Bob wrote:
>> When I try to get the mapfile in cgi mode, a different error appears:
>> loadSymbol(): Unknown identifier. Parsing error near (STYLE):(line 6)
>> *From: * Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
>> *Sent:* Wednesday, December 28, 2011 11:00 AM
>> *To:* Bistrais, Bob; mapserver-users at lists.osgeo.org
>> *Subject:* RE: failed to open map file - MS 6.0 to 6.0.1
>> Nothing should have to be done. 6.0.1 was primarily a security
update.
>> Can you try accessing the mapfile
>> outside PHP with shp2img or mapserv itself?
>> Steve
>> *From: * mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of
>> *Bistrais, Bob
>> *Sent:* Wednesday, December 28, 2011 9:56 AM
>> *To:* mapserver-users at lists.osgeo.org
>> *Subject:* [mapserver-users] failed to open map file - MS 6.0 to
6.0.1
>> I'm trying to upgrade some MapServer applications which were
>originally
>> written before MS 6.0. These had been migrated to 6.0, now I am
trying
>> to upgrade them to 6.0.1. I would have thought nothing needed to be
>> done, but when I try to view these applications, I get the following
>> error message:
>> Warning: ms_newMapObj(): [MapServer Error]: msLoadMap():
>> (../maps/mymap.map) in C:\ms4w\apps\mgs\htdocs\drawMap.php on line
218
>> Fatal error: Uncaught exception 'MapScriptException' with message
>> 'Failed to open map file "../maps/mymap.map"' in
>> C:\ms4w_303\apps\mgs\htdocs\drawMap.php:218 Stack trace: #0
>> C:\ms4w\apps\mgs\htdocs\drawMap.php(218):
>> ms_newMapObj('../maps/mymap...') #1 {main} thrown in
>> C:\ms4w\apps\mgs\htdocs\drawMap.php on line 218
>> -I checked the obvious, such as permissions, paths, etc, but not able
>to
>> figure out what's going wrong here. As mentioned, it works OK in MS
>6.0.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
