[mapserver-users] Order of attributes returned from WFS GetFeature
Dejan Gambin dejan.gambin at coin.hr
Thu Dec 29 06:59:24 EST 2011
Thanks. This works like a charm :-)
dejan
On 29. pro. 2011., at 12:40, Havard Tveite wrote:
> I think your subselect has to include gid.
> Examples on:
> <URL: http://mapserver.org/input/vector/postgis.html#data-access-connection-method >
> Håvard
> On 12/29/2011 12:19 PM, Dejan Gambin wrote:
>> Thanks,
>> I tried something like:
>> DATA "the_geom from (select the_geom, attr1, attr2 from table) as new_table using unique gid"
>> but this doesn't work. Can you tell me how should such a query look like? Now it is like:
>> DATA "the_geom from table using unique gid"
>> Thanks very much
>> regards, dejan
>> On 27. pro. 2011., at 22:13, Rahkonen Jukka wrote:
>>> Hi,
>>> The WFS standard defines that attributes are included in a XML sequence. Therefore the returned attributes must be in the same order than in the schema of your feature type.
>>> I would suggest also having a try with editing the SQL in the DATA line and selecting attributes as you like but check first if it has an effect on the schema returned by DescribeFeatureType.
>>> -Jukka Rahkonen-
>>> ________________________________________
>>> Lime, Steve D (DNR) wrote:
>>>> I don't believe you can control this on the MapServer side. Why not just set the column order
>>>> explicitly in the SQL statement?
>>>> Steve
>>>> -----Original Message-----
>>>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf>  Of Dejan Gambin
>>>> Sent: Thursday, December 22, 2011 7:40 AM
>>>> To: mapserver-users at lists.osgeo.org
>>>> Subject: [mapserver-users] Order of attributes returned from WFS GetFeature
>>>> Hi,
>>>> I am using GetFeature request to get the attributes from my PostGIS data. I define attributes with "gml_include_items". The order of attributes is however related to postgis column order, not to the order in gml_include_items.
>>> Is it somehow possible to change the order, withoout need to modify column order in PostGIS/PostgreSQL?
>>> regards, dejan_______________________________________________
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
