[mapserver-users] setting mapserv path in template
Adam Eskreis
aeskreis at gmail.com
Thu Dec 29 13:27:49 EST 2011
First of all, try using GET instead of POST. Once you make that change,
post the full URL with parameters that you are trying to use and maybe we
can help. One thing I cna say for sure is if those inputs are hte only
parameters you are passing to mapserver, it's probably not enough. I don't
see a parameter there for image type, a bounding box, or image width/height.
On Thu, Dec 29, 2011 at 1:07 PM, gianluca.massei <
agr.gianluca.massei at gmail.com> wrote:
> I'm new in mapserver, I'm following a tutorial but I can't go on. I've
> made a simple mapfile and a template with hidden form like this:
> <form method=POST action="/usr/lib/cgi-bin/**mapserv">
> <input type="submit" value="Click to initialize">
> <input type="hidden" name="program" value="/usr/lib/cgi-bin/**mapserv">
> <input type="hidden" name="map" value="/var/www/mapdata/**maplab.map">
> <input type="hidden" name=zoomsize size=2 value=2>
> <input type="hidden" name="layers" value="geographcs monitoring">
> </form>
> If I open the template with a browser I get a download window and ask me
> If I wont download te mapserv file.
> Could you help me?
> Thanks
> Gianluca
> ______________________________**_________________
> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111229/053a8dfc/attachment.html
