[mapserver-users] WCS
Carlos Ruiz
boolean10001 at yahoo.com
Wed Feb 2 10:37:27 EST 2011
David,
I got several WCS working. Remember that EXTENT must be specified as:
MinX MinY MaxX MaxY
Like this:
EXTENT 667850.414115 2160714.942368 672400.414115 2165844.942368
Cheers
IC Carlos Ruiz
From: David Hildebrand <David.Hildebrand at afsc.ca>
To: mapserver-users at lists.osgeo.org
Sent: Tue, February 1, 2011 5:46:01 PM
Subject: [mapserver-users] WCS
I am trying to develop a WCS layer (1.0.0) and I can successfully issue the
GetCapabilities and DescribeCoverage requests. However, when I issue a
GetCoverage request I get a bounding box error due to bad coordinates. The
layer is also set up as a WMS layer (1.1.1) and a GetMap request works fine.
The metadata ows_srs and ows_resolution parameters are being used in the map
file and these work fine for WMS requests. Should I be using version 1.1.0?
Any ideas?
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca<http://www.afsc.ca>
This communication is intended for the use of the recipient to which it is
addressed, and may contain confidential, personal and/or privileged information.
Please contact Agriculture Financial Services Corporation immediately if you are
not the intended recipient of this communication, and do not copy, distribute,
or take action relying on it. Any communication received in error, or subsequent
reply, should be deleted or destroyed. Please consider the environment before
printing this email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110202/a2a8f03c/attachment.html
