[mapserver-users] WCS
David Hildebrand
David.Hildebrand at afsc.ca
Wed Feb 2 14:11:06 EST 2011
Jukka:
If I issue the request in the same units as the coverage (as shown
below) the request works fine.
REQUEST=GetCoverage
COVERAGE=landsat_test
CRS=EPSG:2956
BBOX=410000,5726000,411000,5727000
RESX=30
RESY=30
FORMAT=GTiff
RESPONSE_CRS=EPSG:2956
If I issue the request in another projection (as shown below) the
request has issues with reprojection.
REQUEST=GetCoverage
CRS=EPSG:4269
BBOX=-113.179,51.761,-113.177,51.763
RESX=30
RESY=30
FORMAT=GTiff
RESPONSE_CRS=EPSG:3400
The service exception I get is
<ServiceException code="NoApplicableCode"
locator="bbox">msWCSGetCoverage(): WCS server error. Requested BBOX
(-98.179,66.761,-98.179,66.761) is outside requested coverage BBOX
(281685,5612685,538515,5840415)</ServiceException>
As you can see, the requested BBOX the server picks up is nowhere near
the BBOX I provide in the URL. The basic content of my map file is
shown below. As you can see the layer is WMS as well as WCS and the WMS
call works fine.
MAP
NAME "mapserv"
OUTPUTFORMAT
NAME 'AGG_JPEG'
DRIVER AGG/JPEG
IMAGEMODE RGB
END
WEB
METADATA
"ows_title" "OGC mapserv"
"ows_contactorganization" "Agriculture Financial Services
Corporation"
"ows_srs" "EPSG:3400 EPSG:2955 EPSG:2956 EPSG:3401 EPSG:3402
EPSG:3403 EPSG:4267 EPSG:4269 EPSG:4326"
"ows_http_max_age" "3"
"wcs_label" "WCS mapserv"
"wcs_onlineresource"
"http://172.16.12.76/cgi-bin/mapserv.wcs.100.exe?"
"wms_feature_info_mime_type" "text/html"
"wms_title" "WMS mapserv"
"wms_onlineresource"
"http://172.16.12.76/cgi-bin/mapserv.wms.111.exe?" END
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
SIZE 1200 1000 #arbitrary...
PROJECTION
"init=epsg:3400"
END
EXTENT 133000 5365600 905200 6721100
UNITS meters
LAYER
NAME "Landsat_test"
METADATA
"ows_srs" "EPSG:2956" #UTM12...
"ows_resolution" "30 30"
"wcs_name" "Landsat_test"
"wcs_label" "Landsat_test 30m"
"wcs_bandcount" "3"
"wcs_rangeset_name" "TheRangesetName"
"wcs_rangeset_label" "TheRangesetLabel"
"wms_title" "Landsat_test"
"wms_opaque" "1"
END
STATUS off
TYPE raster
DATA "//Plcoressatsb01/G$/Landsat/2010/processed/4124_708.tif"
PROJECTION
"init=epsg:2956"
END
DUMP TRUE
END
END
Any help would be appreciated.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Tuesday, February 01, 2011 10:15 PM
To: David Hildebrand; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WCS
Your layer definitions and the GetCoverare request you were using would
help pretty much.
-Jukka Rahkonen-
David Hildebrand wrote:
> I am trying to develop a WCS layer (1.0.0) and I can successfully
issue
the GetCapabilities and DescribeCoverage requests. However, when I
issue a GetCoverage request I get a bounding box error due to bad
coordinates. The layer is also set up as a WMS layer (1.1.1) and a
GetMap request works fine. The metadata ows_srs and ows_resolution
parameters are being used in the map file and these work fine for WMS
requests. Should I be using version 1.1.0?
> Any ideas?
David V. Hildebrand
(403) 782-8239
email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110202/be9f0344/attachment-0001.html
