[mapserver-users] Bug or User error? MINSIZE not working
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 4 01:11:34 EST 2011
On 2/4/2011 12:19 AM, Rahkonen Jukka wrote:
> Hi,
> Documentation shows that MINSIZE under CLASS definitions, not STYLE.
> Have you tried to place it there?
Thanks, I did notice that after I posted. Sadly it does not work there
either. It seems to be documented under both STYLE and CLASS as things
have been getting reworked in this area of the code. I player with
setting MAXSIZE and that seems to work as expected, but I think MINSIZE
is broken. I check it on both 5.6.5 and 5.6.6.
I can write it up as a bug tomorrow.
-Steve W
> -Jukka Rahkonen-
> Stephen Woodbridge wrote:
>> Hi All,
>> Thomas maybe you know this?
>> I have a layer:
> SYMBOL
> NAME "dots"
> TYPE SIMPLE
> STYLE 1 3 END
> END
> LAYER
> NAME "World Admin-1 Z1"
> GROUP "cb"
> STATUS DEFAULT
> TYPE LINE
> DATA "not-nt2/10m-admin-1-states-provinces-lines-shp"
> PROJECTION "init=epsg:4326" END
> MAXSCALEDENOM 50000000
> MINSCALEDENOM 5000000
> CLASS
> STYLE
> COLOR "#aaaaaa"
> SYMBOL "dots"
> WIDTH 1
> MINSIZE 8000.0
> END
> END
> END
>> MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> I can not get any of these lines to turn off. I have tried, variations
> of large MINSIZE values, commenting out the SYMBOL, using SIZE or WIDTH.
> No value of MINSIZE seems to have any impact. A large number of the
> lines are under 5 pixels at the scale I'm using 28M. The lines display
> fine I just need to turn off the short ones to declutter the image.
>> I spent all night on this with no success so I guess its time to ask.
> -Steve W
> mapserver-users at lists.osgeo.org
