[mapserver-users] Bug or User error? MINSIZE not working
thomas bonfort
thomas.bonfort at gmail.com
Sat Feb 5 16:03:07 EST 2011
Steve,
compared to the use-case referred to in the bug, I think things have
changed if you use the cairo or agg renderer as in those cases you
don't end up with a pixel being fully highlighted as gd does.
I wouldn't be against a configurable option to skip small geometries,
but would label this as a performance enhancement rather than a
quality one.
regards,
thomas
On Fri, Feb 4, 2011 at 17:25, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> On 2/4/2011 10:34 AM, Daniel Morissette wrote:
>> On 11-02-04 10:13 AM, Stephen Woodbridge wrote:
>>> On 2/4/2011 2:14 AM, thomas bonfort wrote:
>>>> what are you trying to obtain?
>>> Ah, good question. I am trying to filter out objects the are very small
>>> from rendering. At some zoom levels these objects are just to small to
>>> be meaningful to render and end up looking like dirt on the image.
>> Ah, maybe what you're looking for is MINFEATURESIZE at the layer/class
>> level?
>> http://trac.osgeo.org/mapserver/ticket/1340
> Sigh - at least I'm consistent, needed this 6 years ago, and still need it!
> Looks like it might go in 6.0 if some can tackle it. It looks like we
> already have code to do this as part of the labeling code, it just needs to
> get added in the rendering chain.
> OK, back to the old way of doing this, add length attribute and filter on
> length at different scales.
> -Steve
> mapserver-users at lists.osgeo.org
