[mapserver-users] Legend in vector - SVG
Tim Heuer
HeuerT at landcareresearch.co.nz
Sun Feb 6 20:05:42 EST 2011
Hi List,
Just a solution that came up:
We want to display our legends in print as vectors (svg) and found the following configuration for a .map file:
METADATA
"wms_getlegendgraphic_formatlist" "image/svg+xml,image/gif"
If you then request GetLegendGraphic with parameter &FORMAT=image%2Fsvg%2Bxml you can get it to work.
This however only works in the svn version that we compiled.
Hope this helps someone with the same problem.
Kind regards,
Tim
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110207/1cbb2dbd/attachment.html
