[mapserver-users] PHP Mapscript: generateSLD
Daniel Degasperi
daniel.degasperi at r3-gis.com
Mon Feb 7 09:04:46 EST 2011
I've used the function generateSLD from the layerObj class to create a
sld snippet, but the output was a empty sld file:
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
</StyledLayerDescriptor>
I'm using following mapfile with mapserver 5.6.5:
MAP
NAME "test.map"
SIZE 256 256
RESOLUTION 72
OUTPUTFORMAT
NAME "aggpng24"
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
TRANSPARENT ON
END
WEB
METADATA
"ows_onlineresource"
"http://dev/public/services/ows.php?map=test.map"
"ows_title" "test"
"ows_abstract" ""
"wms_feature_info_mime_type" "text/html"
"ows_service_onlineresource" ""
"wms_srs" "EPSG:32632 EPSG:4326 EPSG:900913"
END
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/tmp/"
END
LAYER
GROUP "test"
NAME "test"
TYPE LINE
STATUS OFF
METADATA
"ows_title" "test"
"ows_extent" "482003.57067363 5006503.5706736
537996.42932637 5062496.4293264"
"ows_srs" "EPSG:32632"
"gml_geometries" "the_geom"
END
PROJECTION
"+proj=utm +zone=32 +ellps=WGS84 +datum=WGS84 +units=m +no_defs "
END
EXTENT 482003.57067363 5006503.5706736 537996.42932637 5062496.4293264
CONNECTIONTYPE POSTGIS
CONNECTION "user=test password=test dbname=test host=localhost
port=5432"
DATA "the_geom FROM test USING UNIQUE gid USING SRID 32632"
PROCESSING "CLOSE_CONNECTION=DEFER"
SIZEUNITS pixels
CLASS
NAME "l103106"
EXPRESSION ('[code]' eq 'L103106')
STYLE
COLOR 76 230 0
SYMBOL "CIRCLE"
SIZE 3
MINSIZE 3
MAXSIZE 3
WIDTH 3
MINWIDTH 3
END
END
CLASS
NAME "l103107"
EXPRESSION ('[code]' eq 'L103107')
STYLE
COLOR 56 168 1
SYMBOL "CIRCLE"
SIZE 2
MINSIZE 2
MAXSIZE 2
WIDTH 2
MINWIDTH 2
END
END
END
###### SYMBOLS #######
SYMBOL
NAME "CIRCLE"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
END #MAP
Can somebody help me?
Best regards,
Daniel
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110207/e90c2dfe/attachment.html
