[mapserver-users] size of legend icon for pixmap-type classes
NASUNO Isao
isao.nasuno at ctc-g.co.jp
Tue Feb 8 03:42:23 EST 2011
Hello all,
I'm trying to make mapfile which includes polygon layer
with pixmap-type symbol classes.
The symbols are defined like ...
SYMBOL
NAME "symbol1"
TYPE pixmap
image /somewhere/symbol1.gif
transparent 1
END
The polygon layer with pixmap is drawn perfectly by map mode,
however in legend mode (mode=legend), the icons drawn like line layer.
How do I say... it seems that mapserver draws icon for line ( /\/ )
like ArcMap's line layer using "brush" of the gif image.
I defined the layer certainly as "type polygon".
layer
name "jimon"
connectiontype postgis
connection "user=db password=xxxxxxx dbname=DB host=localhost port=5432"
data "the_geom from polygon"
status on
type polygon
classitem "id"
projection
"init=epsg:4326"
end
class
name "pattern1 "
expression "1"
style
symbol "symbol1"
end
end
end
What I want is normal rectangle-shaped icons filled up with the gif.
Could anyone help me ?
Thanks,
Isao NASUNO
