[mapserver-users] WMS SLD Troubles
Frank Broniewski
brfr at metrico.lu
Wed Feb 9 03:18:38 EST 2011
Hello,
thank you for your kind help :-) I've put the requested informations below.
Frank
INFO:
we're using
/usr/lib/cgi-bin/mapserv -v
MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
on Ubuntu 8.04 with the ubuntu-gis ppa.
Original layer definition:
LAYER
NAME "post"
STATUS Off
CONNECTIONTYPE Postgis
CONNECTION "host=localhost dbname=osm user= password= port=5432"
DATA "nway FROM
(SELECT way as nway, osm_id, amenity, name
FROM planet_osm_point
WHERE amenity='post_box' OR amenity='post_office'
as foo using unique osm_id using SRID=900913"
TYPE Point
PROCESSING "CLOSE_CONNECTION=DEFER"
CLASSITEM "amenity"
DUMP true
# Projection configuration
INCLUDE "/usr/local/mapconf/share/projections/google.map"
METADATA
# lots of metadata ....
END
END
the SLD:
<NamedLayer>
<Name>post</Name>
<UserStyle>
<Title>Post</Title>
<FeatureTypeStyle>
<Rule>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>amenity</ogc:PropertyName>
<ogc:Literal>post_box</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<PointSymbolizer>
<Graphic>
<ExternalGraphic>
<OnlineResource
xlink:type="simple"
xlink:href="http://192.168.0.111:8502/sld/img/briefkasten.png" />
<Format>image/png</Format>
</ExternalGraphic>
<Size>40</Size>
</Graphic>
</PointSymbolizer>
</Rule>
<Rule>
<Filter>
<PropertyIsEqualTo>
<PropertyName>amenity</PropertyName>
<Literal>post_office</Literal>
</PropertyIsEqualTo>
</Filter>
<PointSymbolizer>
<Graphic>
<ExternalGraphic>
<OnlineResource
xlink:type="simple"
xlink:href="http://192.168.0.111:8502/sld/img/posthorn.png" />
</ExternalGraphic>
<Size>40</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
the generated map file:
LAYER
CLASSITEM "amenity"
CONNECTIONTYPE POSTGIS
DATA "nway FROM
DUMP TRUE
METADATA
# metadata
END
NAME "post"
PROJECTION
"proj=merc"
"a=6378137"
"b=6378137"
"lat_ts=0"
"lon_0=0"
"x_0=0"
"y_0=0"
"k=1"
"nadgrids=@null"
"units=m"
"no_defs"
END
STATUS ON
TYPE POINT
UNITS METERS
CLASS
NAME "Unknown"
EXPRESSION ("[amenity]" = "post_box")
STYLE
ANGLE 360
COLOR 0 0 0
SIZE 40
SYMBOL "http://192.168.0.111:8502/sld/img/briefkasten.png"
WIDTH 1
END
END
END
Am 08.02.2011 15:57, schrieb Yewondwossen Assefa:
> What version of MapServer?
> Also, what is the part in the map file that is causing the problem:
> * if you remove the EXPRESSION ("[amenity]" = "post_box") from the
> generated map, will that work
> * Is the layer's FILTER element set (on the generated map)? If so what
> is the value?
> A full layer definition in the generated map would be useful. A full sld
> might also help.
> regards,
> On 07/02/2011 4:58 AM, Frank Broniewski wrote:
>> Hello,
>> We're using a OpenStreetMap Postgis database as a source for our
>> geo-servers. We want to provide WMS and WFS services on the data. In
>> order to do the styling only once, we are using SLDs, which works
>> mostly fine.
>> One of our layers does not render as a WMS, it throws a
>> "msEvalRegex(): Regular expression error. String failed expression
>> test." Error during execution.
>> We identified the layer, and it's the one rendering post boxes. The
>> corresponding SLD definition is using a filter:
>> <Filter>
>> <PropertyIsEqualTo>
>> </Filter>
>> Using debug-level 5, the mapfile after SLD application looks like
>> # more definitions
>> CLASSITEM "amenity"
>> DATA "nway FROM
>> # more definitions
>> CLASS
>> NAME "Unknown"
>> STYLE
>> ANGLE 360
>> COLOR 0 0 0
>> SIZE 40
>> WIDTH 1
>> END
>> END
>> We simply can't figure out, what might be the problem here. The whole
>> issue seem to be related to the filter element, removing it makes the
>> layer render. Using the generated map layer, rendering fails with the
>> same error.
>> So I would be happy if someone with more experience with SLDs can give
>> me a hint about whats going wrong here.
>> Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
