[mapserver-users] GetfeatureInfo-Request in an UTF-8 environment
with shapfile in cp-1252
Milo van der Linden
milo at dogodigi.net
Wed Feb 9 03:46:37 EST 2011
I found a ticket that is related to this issue:
http://trac.osgeo.org/gdal/wiki/rfc23_ogr_unicode
2011/2/9 Milo van der Linden <milo at dogodigi.net>
> Hello Andreas;
> What return type of getfeatureinfo are you using?
> There are three possibilities: http://mapserver.org/ogc/wms_server.html
> 1. text/plain
> 2. text/html
> 3. gml
> If you use text/html; you can set the character encoding to windows ansi:
> http://www.w3.org/International/questions/qa-html-encoding-declarations#quicklookup
> If you use GML, because it is a "flavour" of XML, mapserver MUST serve
> UNICODE:(UTF-8 or UTF-16);http://www.w3.org/TR/REC-xml/#sec-well-formed
> So if the gml output is not converted to unicode; please file a ticket for
> this matter in the osgeo trac database.
> 2011/2/8 Tom van der Putte <tom at vdputte.nl>
>> Hi Andreas,
>> i looked it up, you can find it here:
>> http://resources.arcgis.com/content/kbase?fa=articleShow&d=21106
>> Unfortunately I'm not aware of any means to automate the process of
>> exporting the shapefiles, so you'd have to do it by hand.
>> Tom
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110209/19630bf3/attachment-0001.html
