[mapserver-users] GetfeatureInfo-Request in an UTF-8 environment
with shapfile in cp-1252
Milo van der Linden
milo at dogodigi.net
Wed Feb 9 05:00:25 EST 2011
There are errors in the usage of "
I think that:
<meta http-equiv="Content-Type" content="text/html;
charset=x-mac-thai"></meta>
is the correct one.
http://www.w3.org/International/O-HTTP-charset
2011/2/9 Siegel Andreas <Andreas.Siegel at vorarlberg.at>
> Hi Tom.
> Thanks for your reply. But no, it is not an issue with ArcGIS.
> The link you sent me may prove useful anyway since we rely heavy on
> shapefiles and ArcGIS ist used by several of our colleges and contributors.
> My issue is this line of code:
> <meta http-equiv="Content-Type" content="text/html";
> charset=MacThai"></meta>
> Please note the charset MacThai.
> This charset should render my results illegible but it has no effect at
> all.
> I test it by using a browser:
> http://vogis.cnv.at/mapserver/mapserv?map=a.map&LAYERS=umlauttest&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/jpeg&SRS=EPSG:31254&BBOX=-49500,246750,-49000,247250&X=250&Y=250&INFO_FORMAT=text/html&QUERY_LAYERS=umlauttest&WIDTH=650&HEIGHT=650&FEATURE_COUNT=30
> and the commandline.
> ./mapserv -nh
> "QUERY_STRING=map=a.map&LAYERS=umlauttest&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&FORMAT=image/jpeg&SRS=EPSG:31254&BBOX=-49500,246750,-49000,247250&X=250&Y=250&INFO_FORMAT=text/html&QUERY_LAYERS=umlauttest&WIDTH=650&HEIGHT=650&FEATURE_COUNT=30"
> The commandline output can be inspected by hexdump -C
> ./mapserv -nh
> | hexdump -c
> This allows to inspect the result without some unwanted/unnoticed code
> translations when using an editor or the browser,
> This are the HTML-Templates:
> Header:
> <!-- MapServer Template -->
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
> http://www.w3.org/TR/html4/transitional.dtd">
> <html>
> <head>
> <!-- enforce the client to display result html as UTF-8 encoding -->
> <style type="text/css">
> table, th, td {
> border:1px solid #e5e5e5;
> border-collapse:collapse;
> font-family: arial;
> font-size: 80%;
> color: #333333
> th, td {
> valign: top;
> text-align: center;
> th {
> background-color: #aed7ff
> caption {
> font-family: arial;
> font-weight: bold;
> font-size: 80%;
> text-align: left;
> color: #333333;
> </style>
> <title>GetFeatureInfo Response</title>
> </head>
> <body>
> <table>
> <caption>Widmungsart Zeichensatztest ae ä oe ö ue ü AE Ä OE Ö UE Ü
> scharfes s ß Ende</caption>
> <tbody>
> <th>Kuerzel</th>
> <th>Widmungsart</th>
> <th>Flaeche</th>
> <th>Text</th>
> TEMPLATE:
> <tr>
> <td>[item name=WI_EM_KN format=$value escape=none]</td>
> <td>[item name=WI_EM_TXT format=$value escape=none]</td>
> <td>[item name=Flaeche format=$value escape=none]</td>
> <td>[item name=FS_TXT format=$value escape=none]</td>
> </tr>
> FOOTER:
> </tbody>
> </table>
> <br/>
> </body>
> </html>
> *Mag Andreas Siegel*
> Landesvermessungsamt Feldkirch
> Johannitergasse 6, A-6800 Feldkirch
> Tel: +43(0) 5522 / 75482 - 60227
> Fax: +43(0) 5522 / 75482 - 6
> E-Mail: andreas.siegel at vorarlberg.at<andreas.andreas.sandreas.siegel at vorarlberg.at>
> http://www.vorarlberg.at/lva
> Rechtsverbindlichen Schriftverkehr
> (zB Anträge, Rechtsmittel) richten Sie an:
> E-Mail: landesvermessungsamt at vorarlberg.at
> Fax: +43(0)5522/75482-6
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110209/73e9a6e2/attachment-0001.html
