[mapserver-users] 3D Building Howto?
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon Feb 14 18:34:57 EST 2011
Maybe this is a GEOMTRANSFORM function in 6.0 speak? You could do something like:
GEOMTRANSFORM (extrude(some view parameters, [height]))
Where the first few arguments define a view position and the last argument is height. Neat thing about this approach that height could be a constant or a bound to an attribute. The extrude function would generate the sides, top and bottom based on view parameters and a height. It could even (perhaps) create multiple features mirrored on the outline but with extended attributes that would define things like top vs. side vs. bottom, or whether a facet side is visible or not.
If done outside of STYLEs (e.g. a layer-level GEOMTRANSFORM) then one could draw things differently based on these pseudo attributes (e.g. if a side and visible do this).
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Monday, February 14, 2011 5:12 PM
To: mapserver-users
Subject: [mapserver-users] 3D Building Howto?
Hi all,
Has anyone been able to render 3D building with mapserver?
I have a polygon layer with the building outlines and a height attribute.
Any thoughts on how to render nice buildings like Google does?
I can preprocess the data and extrude it into 3D shapes, but I'm not
sure that gets me anywhere.
My one thought was to draw the polygon, then draw it again with an xy
offset based on a function of the height. But this does not generate the
vertical edges of the building.
I suppose I could generate all the vertical faces and the top of the
build and then sort them all based on the z value of the centroid. I
could event remove all the back facing polygons faces.
It would be cool if mapserver had:
LAYER
TYPE POLYGON3D
HEIGHT [height]
END
Thoughts?
-Steve W
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
