[mapserver-users] mapscript php with agg rendering?
Michael Schulz
mandschulz at googlemail.com
Tue Feb 15 06:37:37 EST 2011
Hi mapservers,
I have a question regarding the AGG rendering when creating a map
completly from php-mapscript. In the script I (think I) am setting all
the required parameters for the map to be rendered with AGG using
24bit:
$oMap=ms_newMapObjFromString("MAP END");
$oMap->outputformat->set('name','png');
$oMap->outputformat->set('driver','AGG/PNG');
$oMap->outputformat->set('mimetype','image/png');
$oMap->outputformat->set('imagemode',MS_IMAGEMODE_RGBA);
$oMap->outputformat->set('extension','png');
$oMap->outputformat->set('transparent',MS_TRUE);
I've experienced for some time with the following directive, trying to
actually invoke the correct outputformat
$oMap->selectoutputformat("png");
But to no avail. The maps that derive from this script clearly use the
GD driver. When I saved the generated map-file to the filesystem I
found the following line in the map section:
IMAGETYPE gif
I am using MapServer, Mapscript 5.6.6., PHP 5.3.3 on OpenSuse 11.3
Maybe someone could share some mapscript code or has some hints how to
actually return AGG rendered maps.
Thanks, Michael
Michael Schulz
