[mapserver-users] strange raster problem
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Feb 15 11:25:33 EST 2011
Hi list,
we have a strange problem with an ArcSDE raster layer. At certain zoom
levels the pixels are very coarse. Zooming out one level the pixels are
okay, however the colour is not.
You can see this in the following images, the first one is zoomed out and
everything is okay (except the colours since the image should be mostly
black):
http://www.osgis.nl/download/mapserver/rws1.png
However when zooming in one level, we obtain the following situation:
http://www.osgis.nl/download/mapserver/rws2.png
Does anyone have an explanation for this? Using Mapserver trunk from about
3 months back and GDAL 1.7.2.
This is the info from ArcCatalog about the raster layer:
<TreeList><Data_Source><Raster>BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM</Raster><Data_Type>SDE
Raster</Data_Type><Server>geodatabase.ad.rws.nl<User>RWS_LEZEN</User><Instance>5151\tcp</Instance><Database></Database><Version>SDE.DEFAULT</Version></Server></Data_Source><Raster_Information><Columns_and_Rows>1161,
2021</Columns_and_Rows><Number_of_Bands>1</Number_of_Bands><Cellsize__X._Y_>250.00000000000011,
250</Cellsize__X._Y_><Uncompressed_Size>8.95
MB</Uncompressed_Size><Format>SDR</Format><Source_Type>continuous</Source_Type><Pixel_Type>floating
point</Pixel_Type><Pixel_Depth>32
Bit</Pixel_Depth><NoData_Value>-3.402823E+38</NoData_Value><Colormap>absent</Colormap><Pyramids>level:
4, resampling: Nearest
Neighbor</Pyramids><Compression>LZ77</Compression></Raster_Information><Extent><Top>6199911.5560208503</Top><Left>459782.82782689098</Left><Right>750032.82782689109</Right><Bottom>5694661.5560208503</Bottom></Extent><Spatial_Reference>ETRS_1989_UTM_Zone_31N<Linear_Unit>Meter
(1.000000)</Linear_Unit><Angular_Unit>Degree
(0.017453292519943299)</Angular_Unit><False_Easting>500000</False_Easting><False_Northing>0</False_Northing><Central_Meridian>3</Central_Meridian><Scale_Factor>0.9996</Scale_Factor><Latitude_Of_Origin>0</Latitude_Of_Origin><Datum>D_ETRS_1989</Datum></Spatial_Reference><Statistics><Band_1><Build_Parameters>skipped
columns:1, rows:1, ignored value:
</Build_Parameters><Min>0.5</Min><Max>59.80879974365234</Max><Mean>0.831969292920005</Mean><Std_dev.>2.825845448840229</Std_dev.><Classes>0</Classes></Band_1></Statistics></TreeList>
The LAYER definition is:
LAYER
CONNECTIONTYPE SDE
DATA
"SDE:xxxxx.ad.rws.nl,port:5151,5151,RWS_LEZEN,XXXXXX,BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM,RASTER"
DUMP TRUE
EXTENT 459782.827826891 5694661.55602085 750032.827826891 6199911.55602085
NAME "BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM_5925"
PROCESSING 'CLOSE_CONNECTION=DEFER'
PROCESSING 'DITHER=NO'
PROCESSING 'NODATA=NODATA'
PROCESSING 'SCALE_1=0.5,59.8087997436523'
PROCESSING 'BANDS=1'
PROCESSING 'LOAD_FULL_RES_IMAGE=NO'
PROCESSING 'LOAD_WHOLE_IMAGE=NO'
SIZEUNITS PIXELS
UNITS METERS
STATUS ON
TEMPLATE 'blank.html'
TOLERANCE 5
TOLERANCEUNITS PIXELS
TYPE RASTER
PROJECTION
'init=epsg:25831'
END
METADATA
'wms_title' 'Grindpercentage, stretched'
'wms_layer_group' '/Grindpercentage_ NCP'
'wms_metadataurl_format' 'text/xml'
'wms_metadataurl_href'
'http://test.intranet.rijkswaterstaat.nl/services/geoservices-update/metadata/BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM'
'wms_metadataurl_type' 'TC211'
'wcs_abstract' 'noordzee grind en zand raster'
'wcs_bandcount' '1'
# 'wcs_description' 'noordzee grind en zand raster' # Optional
'wcs_extent'
'459782.827826891,5694661.55602085,750032.827826891,6199911.55602085'
'wcs_formats' 'GTiff,MrSID,ECW'
'wcs_keywords' 'RWS,Rijkswaterstaat,noordzee grind en zand
raster,BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM_5925'
'wcs_label' 'Grindpercentage, stretched' # Required
'wcs_metadatalink_format' 'text/xml'
'wcs_metadatalink_href'
'wcs_metadatalink_type' 'TC211'
'wcs_name' 'BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM_5925'
# 'wcs_nativeformat' 'Raster' # Optional
'wcs_rangeset_label' 'Grindpercentage, stretched'
'wcs_rangeset_name' 'BODEM.DNZ_GRINDPERCENTAGE_TOT_15CM_5925'
END
PROCESSING 'SCALE_BUCKETS=256'
CLASS
STYLE
COLORRANGE 0 0 0 255 255 255
DATARANGE -4.81972160476045 6.48366019060046
RANGEITEM "pixel"
END
END
END
TIA.
Best regards,
Bart
