[mapserver-users] How i check Mapserver is installed or not ?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Feb 18 06:53:59 EST 2011
In MS4W case your test is valid and http://localhost:8080/ should show you the MS4W main web page. Moreover, a better test to see if Mapserver CGI is found is to send http://localhost:8080/cgi-bin/mapserv.exe It should return
"No query information to decode. QUERY_STRING is set, but empty. "
Obviously your Apache is not running. Two suggestions:
- Open a command window and run ms4w\apache-install.bat from there. You may see some messages on the screen.
- If Apache does not start that way it can be because something prevents Windows to install Apache as a service. Try then to run is executable by opening a command window, going to ms4w\apache\bin and running httpd.exe. Look at the screen for error messages.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Mustafa646
> Lähetetty: 18. helmikuuta 2011 12:27
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] How i check Mapserver is installed or not ?
> I have installed MS4W (full) and choose port 8080 because on
> port 80 i have
> already installed IIS7. Now installation of MS4W is
> successful , but how i
> check ? I put http://localhost:8080/ in my browser, but i
> could not see the
> page.
> any idea how to fix it ?
> http://osgeo-org.1803224.n2.nabble.com/How-i-check-Mapserver-i
> s-installed-or-not-tp6039430p6039430.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
