[mapserver-users] TEMPLATE generation completion (NOT!)
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Feb 18 10:32:28 EST 2011
I would assume it's barfing before it even gets to the footer. Are you absolutely sure the surface class record is being processed completely for all search results?
If you break the footer name intentionally in the mapfile does MapServer complain?
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bob Basques
Sent: Friday, February 18, 2011 9:27 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] TEMPLATE generation completion (NOT!)
All,
I've been chasing this one around for a day now.
For some reason (might be a part of our funky configuration too, but ) a TEMPLATE "FOOTER" will not get pasted to the bottom of the output.
The HEADER and RECORD values populate just fine, I have many (MANY) other layers in the same configuration that work just fine as well.
My question, anyone got and ideas about why a FOOTER template chunk will not populate on a MapServer request?
I've looked at:
* Permissions on the file (same as all others)
* Content of TEMPLATE chunk (it only contains "</imagemap>" ), I even recreated it a couple of times manually.
* I checked the mapfile (but everything else works, the legend, the image output, the HEADER and RECORD output . . .
* The data is even popping out in the IMAGEMAP correcrtly.
* Moved around the map with different areas of interest, different numbers of returned records.
Thanks (from bewildered!!)
bobb
Here is the MAPFILE and TEMPLATES:
MAP
NAME 'RSVP'
EXTENT 573387 162092 574211 162555
STATUS ON
SYMBOLSET inventory.symbols
FONTSET RESOURCES/inventory.fonts
TRANSPARENT TRUE
IMAGETYPE PNG
LAYER
METADATA
"ows_title" "Surface Class"
"gml_include_items" "all"
"qstring_validation_pattern" "."
"fido_search_items" ""
"fido_search_titles" ""
END
NAME 'SURFACE CLASS'
GROUP 'SURFACE CLASS'
DATA 'DATA/Surface_Class'
STATUS DEFAULT
TYPE POLYGON
CLASSITEM 'GRIDCODE'
CLASS
NAME 'Tree Canopy'
EXPRESSION /1/
COLOR 38 94 0
OUTLINECOLOR 100 100 100
END
CLASS
NAME 'Turf/Grass'
EXPRESSION /2/
COLOR 203 214 139
END
CLASS
NAME 'Bare Soil'
EXPRESSION /3/
COLOR 168 112 0
END
CLASS
NAME 'Water'
EXPRESSION /4/
COLOR 151 219 242
END
CLASS
NAME 'Buildings'
EXPRESSION /5/
COLOR 92 43 0
END
CLASS
NAME 'Impervious Surface'
EXPRESSION /6/
COLOR 78 78 78
END
TEMPLATE './TEMPLATES/surface_class_record.xml'
HEADER './TEMPLATES/surface_class_header.xml'
FOOTER './TEMPLATES/surface_class_footer.xml'
END
END
Header
<?xml version="1.0"?>
<imagemap>
<error message="[errmsg_esc]"/>
<style name="Inventory">
<title>
<attr name="background" value="black"/>
<attr name="fontWeight" value="bold"/>
<attr name="color" value="white"/>
</title>
<contents>
<attr name="background" value="white"/>
</contents>
</style>
Record
<popup class="Inventory" shape="poly" coords="[shpxy xf="," proj=image],10"
ground="[shpxy]">
<title>Surface Classification</title>
<item title="Grid Code:">[GRIDCODE]</item>
</popup>
Footer -- (OUTPUT BREAKS HERE!!!)
</imagemap>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110218/7c81d3fb/attachment-0001.html
