[mapserver-users] problem of legend icon for pixmap-filling type
polygon layer
Isao NASUNO
isao.nasuno at ctc-g.co.jp
Sun Feb 20 19:43:40 EST 2011
Hello Steve,
Thank you for your advice, I had not used the KEYIMAGE option.
It works fine.
No problem to make same-sized chips.
It closed. thank you again,
Isao
(2011/02/19 0:55), Lime, Steve D (DNR) wrote:
> I can confirm the issue. Not sure what's going on but something's broken in the legend generation. I'll try and sum
> things up and file a ticket against 5.6. We won't patch back to 5.0 for something like this.
> As a workaround you might consider setting a KEYIMAGE in your class definition. Make it the same size as your legend
> "chips" (usually something like 25x15) and that image will be used instead of creating one dynamically. I tried that
> here and it seems to work. You should be able to clip a section of a MapServer-created map out for this purpose.
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Isao NASUNO
> Sent: Thursday, February 17, 2011 6:29 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
> Hello Steve,
> I am using gd-2.0.33, with MapServer 5.0.2.
> Thank you,
> Isao
> (2011/02/18 6:54), Lime, Steve D (DNR) wrote:
>> Which driver are you using (AGG or GD)? I'll run some tests here and report back... Steve
>> Sent: Wednesday, February 16, 2011 11:20 PM
>> Subject: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
>> Hello all,
>> I had send same question 2 weeks ago but I have no response,
>> so I try again with more detail of the problem.
>> ** situation **
>> I'm trying to make pixmap-filled polygon maps and I did it without problem,
>> however a problem in getting legend.
>> I want legend icons by mapserver cgi with request "mode=legend" like following.
>> (base pattern) (what I want)
>> oxoxoxoxoxox
>> xoxoxoxoxoxo
>> oxox oxoxoxoxoxox
>> xoxo ------> xoxoxoxoxoxo
>> However I get following. It is like a legend icon of line layer.
>> oxox oxox
>> oxoxox oxoxo
>> oxoxoxoxoxoxo
>> oxoxo oxoxoxo
>> oxoxo oxoxo
>> xoxo xoxo
>> ** version **
>> I'm using MapServer 5.0.2 on CentOS 5.2.
>> I also try MapServer 5.6.x (forgot for detail), but the situation is same.
>> ** what I did **
>> The symbol is defined like ...
>> SYMBOL
>> NAME "symbol1"
>> TYPE pixmap
>> image /somewhere/symbol1.gif
>> transparent 1
>> END
>> The layer is as following...
>> layer
>> name "jimon"
>> connectiontype postgis
>> connection "user=db password=xxxxxxx dbname=DB host=localhost port=5432"
>> data "the_geom from polygon"
>> status on
>> type polygon
>> classitem "id"
>> projection
>> "init=epsg:4326"
>> end
>> class
>> name "pattern1 "
>> expression "1"
>> style
>> symbol "symbol1"
>> end
>> end
>> end
>> Could anyone please help me !?
>> Isao
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
