AW: [mapserver-users] Troubleshooting a cascading mapserver install.
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Mon Feb 21 06:26:11 EST 2011
Just tried a simple request on a WMS server you're cascading: http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?layers=nexrad-n0r-m05m&STYLES=&FORMAT=image/png&width=512&height=512&bbox=-180,-90,+180,+90
resulted in the following error:
msSaveImageGD(): Unable to access file. Unable to open file /mesonet/www/html/tmp/nexrad_base_reflect129828395630777.gif for writing
Looks like the cascaded ones already have a problem. Check that first.
HTH
-----Ursprüngliche Nachricht-----
Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Gregory
Gesendet: Samstag, 19. Februar 2011 20:31
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] Troubleshooting a cascading mapserver install.
Hi all, I've recently setup a mapserver install on a linux machine. So
far the mapfile is written to pull other images from other servers. But
unfortunately I get a blank return image and using google earth to
display shows a big red "X"!
Here's the mapfile:
# Start of map file
MAP
NAME BLACKBERRY
STATUS ON
SIZE 1000 1000
EXTENT -180 -90 180 90
IMAGECOLOR 139 137 137
IMAGETYPE PNG24
UNITS DD
WEB
IMAGEPATH "/home/greg/public_html/mapserverdemo/tmp"
IMAGEURL "/tmp/"
METADATA
WMS_TITLE "Blackberry WMS Server"
WMS_ABSTRACT "This is a WMS application for display on a blackberry."
WMS_ACCESSCONSTRAINTS "none"
WMS_SRS "EPSG:4326"
END
END
LAYER
NAME "CONUS NEXRAD Base Reflectivity (n0r)"
STATUS ON
TYPE RASTER
CONNECTION
"http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?"
CONNECTIONTYPE WMS
METADATA
"wms_format" "image/png"
"wms_srs" "EPSG:4326"
"wms_name" "nexrad-n0r-m05m"
"wms_server_version" "1.1.1"
END
END
LAYER
NAME "CONUS NEXRAD Storm Total Precipitation (ntp)"
STATUS ON
TYPE RASTER
CONNECTION
"http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/ntp.cgi?"
CONNECTIONTYPE WMS
METADATA
"wms_name" "nexrad-ntp"
END
END
LAYER
NAME "NWS Current Polygon Warnings"
STATUS ON
TYPE RASTER
CONNECTION "http://mesonet.agron.iastate.edu/cgi-bin/wms/us/wwa.cgi?"
CONNECTIONTYPE WMS
METADATA
"wms_name" "warnings_p"
END
END
END # Map File
Testing with shp2img works and I get some nice outputs from my mapfile.
But once I pop it into a wms client, nothing seems to show. Is it my
extents boundaries?
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
