[mapserver-users] Compiling with opengl support
thomas bonfort
thomas.bonfort at gmail.com
Tue Feb 22 12:26:10 EST 2011
Felipe,
opengl support should compile and run in the trunk version of
mapserver, you'll have to do a checkout if you want to try it out.
please report back the bugs you see ;)
thomas
On Tue, Feb 22, 2011 at 16:38, Felipe Alcacibar <falcacibar at gmail.com> wrote:
> Hi, i am trying to compile mapserver with the experimental opengl
> support for experimental proposes too, but i cannot do it, i am using
> mesa opengl, gentoo 64bits linux system and mapserver 5.6.6 but it
> seems like this little problems that i cannot figure =/.
> are a solution to this, i need another library, another implementation
> of opengl?
> mapogl.cpp: In function ‘int msPopulateRendererVTableOGL(rendererVTableObj*)’:
> mapogl.cpp:225: error: invalid conversion from ‘void (*)(imageObj*,
> shapeObj*, colorObj*, double, int, double*)’ to ‘void (*)(imageObj*,
> shapeObj*, strokeStyleObj*)’
> mapogl.cpp:242: error: invalid conversion from ‘void (*)(imageObj*,
> shapeObj*, void*)’ to ‘void (*)(imageObj*, shapeObj*, imageObj*)’
> mapogl.cpp:243: error: invalid conversion from ‘void (*)(void*)’ to
> ‘void (*)(imageObj*)’
> wait for your ansewers, thanks in advice.
> Felipe Alcacibar Buccioni
> mapserver-users at lists.osgeo.org
