[mapserver-users] Trouble with WFS GetFeature: get same feature
returned multiple times
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Feb 25 07:59:19 EST 2011
I just tried this with my test data and url similar you yours [1] and
was not able to reproduce it locally using 5.4 and 5.6. If your data/map
are not sensitive, would it be possible to send it to me directly and I
will give it a try again (It would be easier for me to see the problem)?
best regards
[1];
http://127.0.0.1/cgi-bin/mapserv.exe?map=f:/projects/mapserver-buildkit-2008/mapserver/msautotest/wxs/wfs_filter_mine2.map&&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=popplace_postgis&featureid=popplace_postgis.Tignish,popplace_postgis.Cheticamp,popplace_postgis.Halifax
On 24/02/2011 7:33 PM, Rainer Spittel wrote:
> Hi,
> I didn't had problems with UMN Mapserver for a very long time. I
> really love the product, and now I really need help.
> I set up a WFS Server, accessing a PostGIS point table. I use
> OpenLayers to visualise the WFS layer, and use the cluster strategy to
> group close points to a large cluster point.
> Now to the problem:
> I want to retrieve the feature data from a cluster point. I already
> have the IDs of the features of the cluster.
> Now I send a GetFeature request to the Mapserver to get all attribute
> information for the features, i.e. ID=231 and ID=273:
> http://[...]/cgi-bin/stations?request=getfeature&service=WFS&version=1.0.0&typename=DTIS&OUTPUTFORMAT=gml3&featureid=DTIS.231,DTIS.273
> <http://[...]/cgi-bin/stations?request=getfeature&service=WFS&version=1.0.0&typename=DTIS&OUTPUTFORMAT=gml3&featureid=DTIS.231,DTIS.273>
> The response of this request contains the feature 231 twice in the
> response. If I add another ID to the request, I get the feature 231
> three times returned:
> <gml:featureMember>
> <ms:DTIS gml:id="DTIS.231">
> <gml:boundedBy>[...]</gml:boundedBy>
> <ms:msGeometry>
> <gml:Point srsName="EPSG:4326">
> <gml:pos>174.081500 -34.949500</gml:pos>
> </gml:Point>
> </ms:msGeometry>
> <ms:id>231</ms:id>
> </ms:DTIS>
> </gml:featureMember>
> <gml:featureMember>
> </ms:msFeatureCollection>
> As soon as I export the table from PostgreSQL into a shapefile, update the mapfile to use the shapefile and run the same query, I get the correct response.I also tracked the SQL query, which is sent to Postgres, and the query is correct. PostgreSQL returns the correct rows.
> I use MapServer V5.4.1, which is not a very newer version,but I am constraint by the Debian packages.
> Is this an user error (I am not smart enough)? Or a bug? If so, has this bug been resolved in a later version?
> Any help is really appreciated.
> Thanks,
> Rainer
> Rainer Spittel | Head of Development
> SilverStripe
> http://silverstripe.com <http://silverstripe.com/>
> Phone: +64 4 978 7330
> Mobile: +64 21 1390370
> Skype: fb3rasp
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110225/5613d0f5/attachment-0001.html
