[mapserver-users] Re: Raster dataset recommendations
Edi.Karadumi
edikaradumi at gmail.com
Fri Feb 25 10:08:48 EST 2011
Since it as less than 4gb, if you have the image in different tiles just
merge them together. The image format should be tif.
1- Fisrt enable internal tiling with the command
gdal_translate -co "TILED=YES" original.tif tiled.tif
2-than add overviews
gdaladdo -r average 2 4 8 16 32 64 128
3-create a tileindex
gdaltindex myindex.shp *.tif
4-than create a spatial index
shptree myindex.shp
and finally add the layer to the map
LAYER
NAME myorthos
TYPE RASTER
DUMP TRUE
STATUS ON
TILEINDEX ../data/myindex
TILEITEM Location
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Raster-dataset-recommendations-tp6064491p6064777.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
