[mapserver-users] TEMPLATE generation completion (NOT!)
Bob Basques Bob.Basques at ci.stpaul.mn.us
Thu Feb 24 14:29:57 EST 2011
All,
Ok, this problem has returned, and on the same layer.   I've traced
everything around even through our weird file repository, I've made sure
everything is synced on the backend file servers and the files are all
replicated as they should be, with the proper permissions.  I cannot get
this particular layer to output the closing tag in the imagemap.
any other ideas on what to check?
bobb
Steve,
Ok, I have no idea what happened, but fixing the name of the footer
file (back to what it was) fixed the call, it now pops out with the
FOOTER content.
Must have been some weird permission error, but wouldn't that throw an
error just like breaking the name?   Looks like it fixed itself as a
result of editing the name . . . .
Thanks, I think, (I'm going to leave it alone for a while while it's
working . . . . ;c)  I still wonder what went on there though.
I should mention too that this is updating via WEBDAV, I always forget
this part because I use it day in and day out and it's always there as a
folder.  Also, all the configuration files reside inside of SVN.
Anyway, those are the funky configuration elements I was talking about
earlier.
Thanks again, though really, this one was driving me over the edge . .
bobb
>>> "Lime, Steve D (DNR)" <Steve.Lime at state.mn.us> wrote:
I would assume it’s barfing before it even gets to the footer. Are you
absolutely sure the surface class record is being processed completely
for all search results?
If you break the footer name intentionally in the mapfile does
MapServer complain?
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bob
Basques
Sent: Friday, February 18, 2011 9:27 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] TEMPLATE generation completion (NOT!)
All,
I've been chasing this one around for a day now.
For some reason (might be a part of our funky configuration too, but )
a TEMPLATE "FOOTER" will not get pasted to the bottom of the output.
The HEADER and RECORD values populate just fine, I have many (MANY)
other layers in the same configuration that work just fine as well.
My question, anyone got and ideas about why a FOOTER template chunk
will not populate on a MapServer request?
I've looked at:
*  Permissions on the file (same as all others)
*  Content of TEMPLATE chunk  (it only contains "</imagemap>" ), I even
recreated it a couple of times manually.
*  I checked the mapfile (but everything else works, the legend, the
image output, the HEADER and RECORD output . . .
*  The data is even popping out in the IMAGEMAP correcrtly.
* Moved around the map with different areas of interest, different
numbers of returned records.
Thanks  (from bewildered!!)
bobb
Here is the MAPFILE and TEMPLATES:
MAP
  NAME 'RSVP'
  EXTENT 573387 162092 574211 162555
  STATUS ON
  SYMBOLSET inventory.symbols
  FONTSET RESOURCES/inventory.fonts
  TRANSPARENT TRUE
  IMAGETYPE PNG
  LAYER
   METADATA
    "ows_title" "Surface Class"
    "gml_include_items" "all"
    "qstring_validation_pattern" "."
    "fido_search_items" ""
    "fido_search_titles" ""
   END
   NAME 'SURFACE CLASS'
   GROUP 'SURFACE CLASS'
   DATA 'DATA/Surface_Class'
   STATUS DEFAULT
   TYPE POLYGON
   CLASSITEM 'GRIDCODE'
   CLASS
    NAME 'Tree Canopy'
    EXPRESSION /1/
    COLOR 38 94 0
    OUTLINECOLOR 100 100 100
   END
   CLASS
    NAME 'Turf/Grass'
    EXPRESSION /2/
    COLOR 203 214 139
   END
   CLASS
    NAME 'Bare Soil'
    EXPRESSION /3/
    COLOR 168 112 0
   END
   CLASS
    NAME 'Water'
    EXPRESSION /4/
    COLOR 151 219 242
   END
   CLASS
    NAME 'Buildings'
    EXPRESSION /5/
    COLOR 92 43 0
   END
   CLASS
    NAME 'Impervious Surface'
    EXPRESSION /6/
    COLOR 78 78 78
   END
   TEMPLATE './TEMPLATES/surface_class_record.xml'
   HEADER './TEMPLATES/surface_class_header.xml'
   FOOTER './TEMPLATES/surface_class_footer.xml'
  END
END
Header
<?xml version="1.0"?>
<imagemap>
<error message="[errmsg_esc]"/>
<style name="Inventory">
<title>
<attr name="background" value="black"/>
<attr name="fontWeight" value="bold"/>
<attr name="color" value="white"/>
</title>
<contents>
<attr name="background" value="white"/>
</contents>
</style>
Record
<popup class="Inventory" shape="poly" coords="[shpxy xf=","
proj=image],10"
ground="[shpxy]">
<title>Surface Classification</title>
<item title="Grid Code:">[GRIDCODE]</item>
</popup>
Footer  -- (OUTPUT BREAKS HERE!!!)
</imagemap>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110224/38c3c2b5/attachment-0001.html
