[mapserver-users] need an urgent help about changing localhost
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Feb 26 14:08:41 EST 2011
On 2/26/2011 12:58 PM, ahmet temiz wrote:
> hello
> I need an urgent help.
> I am confused.
> Do I have to change localhost to a another host during production
> stage in map file ?
> CONNECTIONTYPE postgis
> CONNECTION "dbname='bzk2' host=localhost port=5432 user='orkun'
> password='222222'"
> I will appreciate if you supply an explanation
> kind regards
localhost is a generic name the refers to the 127.0.0.1 which is the
host that the process is running on.
So if in production you server is on the same system as mapserver and
postgresql is setup to answer connections from localhost then you do not
need to change anything.
If you have a separate host that the database is running on then tiy
will need to change "localhost" to point to the host that the database
is running on. And the database must be configured to accept connection
from the mapserver host.
-Steve W
