[mapserver-users] Projection problems
basvmrs
bas at cipix.nl
Fri Jan 7 05:26:01 EST 2011
I've created a map server in which I try to output data that was entered
using Google Maps V2 (drawing polygons). I used openlayers to display the
results over a Bing layer.
There seems to be a problem in the projection, which is best described using
an image and a link:
http://bir.cipixtest.nl/resources/gis/demo.html Demo
http://osgeo-org.1803224.n2.nabble.com/file/n5898717/forum.png
Notice how the areas seem to 'shift' when zooming in.
My mapfile looks like this:
# Start of map file
MAP
NAME BIR
STATUS ON
SIZE 600 600
EXTENT 4.4 51.85 4.6 51.95
UNITS METERS
IMAGETYPE PNG
PROJECTION
"init=epsg:900913"
END
TRANSPARENT ON
LAYER
NAME bedrijventerreinen
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "MySQL:bir,host=XXXXX,user=XXXXX,password=XXXXXXX,port=3306"
DATA "SELECT * from gis_object"
DUMP TRUE
CLASS
NAME 'Bedrijventerreinen'
STYLE
OUTLINECOLOR 0 0 0
COLOR 200 200 200
END
END
TEMPLATE "object.html"
METADATA
gml_include_items "all"
WMS_TITLE "Bedrijventerreinen"
WMS_ABSTRACT "Bedrijventerreinen in de Regio Rotterdam; de gebieden zijn
een benadering en er kunnen geen rechten aan worden ontleend."
WMS_SRS "EPSG:28992 EPSG:900913 EPSG:4326"
END
END
END # Map File
I don't have a clue why this is happening. I hope that someone can explain
to me why this is happening and how to fix it.
Kind regards,
Bas
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Projection-problems-tp5898717p5898717.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
