[mapserver-users] How would I modify a map file so that when a getcapabilities is run it outputs as tiled layers (wms-t) including listing resolutions listed below:
Yewondwossen Assefa yassefa at dmsolutions.ca
Tue Jan 11 11:05:52 EST 2011
  Not sure I understand well the question: Mapserver does not support
tiled layers by itself. Usually when doing tiles, you will use tilecache
servers (tilecache.org, or mode-geocache
http://code.google.com/p/mod-geocache/  ) that can be set up to
possibly use MapServer as rendering engine .
  Wehn you mention getcapabilities, are referring to the getcapabilities
support in the WMTS (web map tiling service from OGC)? If that is the
case, I would recommend again to  check the tilecache libraries
mentioned above.
If this does not reflect what you intend to accomplish, please give more
details on what you expect from MapServer.
best regards,
> below:
> <Resolutions>
> 0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.1457672119140625E-5,1.0728836059570312E-5,5.364418029785156E-6,2.682209014892578E-6,1.341104507446289E-6,6.705522537231445E-7,3.3527612686157227E-7
> </Resolutions>
> Thanks,
> John
> John J. Mitchell
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110111/2cd5baa6/attachment.html
