[mapserver-users] WARNING: Mandatory metadata '..._GROUP_TITLE' was missing in this
Eckert, Ralf ralf.eckert at stadt-gummersbach.de
Wed Jan 12 02:38:01 EST 2011
The system was created for this website:
http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
UMN MapServer as Server on Linux 5.6.5 is used incl PROJ4, PostgreSQL / PostGIS
As the district map Cologne has been deposited.
The self-test with the command:
/ path/to/mapserver/shp2img-m-o osm.map osm.png
led to a usable image, s: http://gis.gummersbach.de/koeln.png
The map file was installing itself, and OSM
supplemented with the epsg of me: Currently running the following map file:
MAP
OUTPUTFORMAT
    NAME agg
    DRIVER AGG/PNG
    IMAGEMODE RGB
    FORMATOPTION "INTERLACE=false"
    MIMETYPE "image/png"
END
FONTSET "fonts.lst"
IMAGETYPE agg
MAXSIZE 4000
SIZE 800 800
EXTENT 5.8668561 50.3353631 7.7911996 51.2502162
UNITS meters
IMAGECOLOR "#B3C6D4"
WEB
    METADATA
        wms_srs "epsg:900913 epsg:31467 epsg:31493 epsg:4326"
        labelcache_map_edge_buffer "-10"
        wms_title "osm stadt-gummersbach"
    END
END
DEBUG 10
CONFIG "PROJ_LIB" "/home/gkz212/tmp/mapserver-utils"
CONFIG "MS_ERRORFILE" "stderr"
PROJECTION
  "init=epsg:4326"
END
LAYER
    TYPE POLYGON
    STATUS ON
    GROUP "default"
    NAME "land"
    PROJECTION
        "init=epsg:900913"
    END
    DATA "coastlines/processed_p"
    CLASS
        STYLE
            COLOR "#EDEBE6"
            OUTLINECOLOR "#EDEBE6"
        END
    END
END
END
Do I get the following error message GetCapabilities:
  <Layer>
    <Name>MS</Name>
    <Title>osm stadt-gummersbach</Title>
    <Abstract>MS</Abstract>
    <SRS>epsg:900913</SRS>
    <SRS>epsg:31467</SRS>
    <SRS>epsg:31493</SRS>
    <SRS>epsg:4326</SRS>
    <LatLonBoundingBox minx="5.86686" miny="50.3354" maxx="7.7912"
maxy="51.2502" />
    <BoundingBox SRS="EPSG:4326"
                minx="5.86686" miny="50.3354" maxx="7.7912" maxy="51.2502" />
    <Layer>
      <Name>default</Name>
<!-- WARNING: Mandatory metadata '..._GROUP_TITLE' was missing in this context.
      <Title>default</Title>
      <Abstract>default</Abstract>
      <Layer queryable="0" opaque="0" cascaded="0">
        <Name>land</Name>
<!-- WARNING: Mandatory metadata '..._title' was missing in this context. -->
        <Title>land</Title>
        <SRS>EPSG:900913</SRS>
        <LatLonBoundingBox minx="-180" miny="-85.0512" maxx="180" maxy="83.6693"
        <BoundingBox SRS="EPSG:900913"
                    minx="-2.00375e+07" miny="-2.00377e+07" maxx="2.00375e+07"
maxy="1.84644e+07" />
      </Layer>
    </Layer>
  </Layer>
Does anyone have an approach as I get this error fixed?
The attempt to replace the double quotes with simple, gives the same error.
Ralf Eckert
Stadtverwaltung Gummersbach
FB9 - GIS / Vermessung
Rathausplatz 1
51463 Gummersbach
Tel: 02261 - 872303
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110112/6952dd17/attachment.html
