[mapserver-users] Apache installation for ms4w
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jan 21 08:47:42 EST 2011
Hello David,
First, all questions related to MS4W should be sent to the MS4W-users
mailing list, where hundreds of users and devs can assist you with your
issues (subscribe at http://lists.maptools.org/mailman/listinfo/ms4w-users).
As you mentioned, MS4W is designed for new installations and contains a
ready to use Web server and everything you need to move forward.  If you
need to use MS4W in an existing environment, there are some options:
  - follow the existing notes to install in other environments in your
local README file
(http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#k-installing-the-ms4w-mapserver-binaries-in-other-environments)
  - search the MS4W mailing list for other users asking this same
question and the responses (search at:
http://osgeo-org.1803224.n2.nabble.com/ms4w-users-f4995553.html)
  - contact me directly for assistance
Hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-01-20 7:51 PM, David Hildebrand wrote:
> The installation package for ms4w contains a preconfigured version of
> Apache. This works well for a new installation. In the case of an
> existing Apache installation what are the requirements which need to be
> met for ms4w? Are there potential conflicts to be aware of?
