[mapserver-users] Apache installation for ms4w
David Hildebrand
David.Hildebrand at afsc.ca
Fri Jan 21 12:25:05 EST 2011
Thanks, Jeff. I didn't realize there was a separate mailing list for
MS4W.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff
McKenna
Sent: Friday, January 21, 2011 6:48 AM
To: mapserver-users
Subject: Re: [mapserver-users] Apache installation for ms4w
Hello David,
First, all questions related to MS4W should be sent to the MS4W-users
mailing list, where hundreds of users and devs can assist you with your
issues (subscribe at
http://lists.maptools.org/mailman/listinfo/ms4w-users).
As you mentioned, MS4W is designed for new installations and contains a
ready to use Web server and everything you need to move forward. If you
need to use MS4W in an existing environment, there are some options:
- follow the existing notes to install in other environments in your
local README file
(http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#k-ins
talling-the-ms4w-mapserver-binaries-in-other-environments)
- search the MS4W mailing list for other users asking this same
question and the responses (search at:
http://osgeo-org.1803224.n2.nabble.com/ms4w-users-f4995553.html)
- contact me directly for assistance
Hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-01-20 7:51 PM, David Hildebrand wrote:
> The installation package for ms4w contains a preconfigured version of
> Apache. This works well for a new installation. In the case of an
> existing Apache installation what are the requirements which need to
be
> met for ms4w? Are there potential conflicts to be aware of?
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
