[mapserver-users] how to render labels on lines?
Christy Nieman cnieman at dmsolutions.ca
Wed Jan 26 07:41:38 EST 2011
Hello Sergey,
Using "ANGLE FOLLOW" in the label block will provide labels that follow
the curvature of the line segment that is being labelled.  Please note,
that if the line segment is shorter than the label, the label will hang
off the end of the line unless you use MINFEATURESIZE AUTO in the label
block as well.
On 01/26/2011 05:52 AM, Теплов Сергей Геннадьевич wrote:
> Hello!
> I have a problem with using mapserver to render streets and labels to them.
> I want  the labels to be rendered on the streets. If a street has any turn I want to have a curved label to it.
> So, I read an article about that: http://mapserver.org/development/rfc/ms-rfc-11.html#rfc11 .
> This idea was passed in 2006, but I haven't found any messages about solution.
> I am using mapserver-5.6.6.tar.gz  release, but keyword "FOLLOW" doesn't work right, see screenshot.
> I think it is a common task. What is the easiest way to solve this problem?
> Thanks, Sergey.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110126/e382ac29/attachment.html
