[mapserver-users] Re: configure: error: Unable to link against
-L/usr/lib -lfcgi
pcaeiro
pjbcaeiro at gmail.com
Fri Jan 28 06:46:58 EST 2011
Hello thanks for the help,
I am using Centos. :)
You were rigth, i miss the fcgi-devel packadge...
I installed and the mapserver configure command ran without problems, such
as the make, but the fact is that when I run the command "mapserver -v" the
result is this:
"MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=AGG SUPPORTS=ICONV SUPPORTS=FREETYPE TIFF
INPUT=INPUT=JPEG INPUT=INPUT EPPL7=SHAPEFILE"
still lacks the support for fcgi, there may be a problem installing the
packages?
I did a search and found all the packages in the right place so I think that
is correct.
I am missing something.
Tanks,
Paulo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/configure-error-Unable-to-link-against-L-usr-lib-lfcgi-tp5969330p5969570.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
