[mapserver-users] Mapserver WMS server, IIS and wrong content-type
Oliver Christen
oliver.christen at camptocamp.com
Tue Jul 5 02:14:18 EDT 2011
Hello Jeff
Thank you for the informations,
I have transmitted what you told me to my client's IIS admin, I will see
if they can work it on by themself or if they need further assistance.
Thanks again
best regards
Oliver
> Hello Oliver,
> Here is some more info, taken from
> http://www.libpng.org/pub/png/pngstatus.html :
> "As a related item, note that Microsoft's Internet Information Server
> (a.k.a. IIS) shipped by default without an explicit MIME type for PNG
> images until version 6, which effectively meant that it treated PNGs
> as application/octet-stream rather than image/png. Not surprisingly,
> this affected only non-Microsoft web browsers connecting to IIS
> servers; they rightly refused to display such mislabelled PNGs.
> Fortunately, Microsoft did finally correct the problem with the
> release of IIS 6.0 in 2003, and a fix is available for older versions
> (at least for version 4.0)."
> So that goes along with my initial ideas.
> Anyway those are my quick thoughts on your problem with your client's
> IIS instance. If you want to contact me directly and we can work
> through this together with your client please do.
> -jeff
